MYFORD - SWIVELING VERTICAL SLIDE
Harry Wilkes08/11/2013 15:27:09
1613 forum posts
72 photos
Hi all would again welcome some advise my lathe came with a Myford swiveling vertical slide but unlike the photo below
mine does not have a single bolt through the base, mine as a threaded tube which secures the bottom swivel then a 'tee' bolt which passes through the tube clamps the slide in place. Do I take it mine is wrong and the photo above is correct.
Thanks H
DMB08/11/2013 15:53:25
1585 forum posts
Hi Harry,
I have the old design as pictured by you, which appears to be all present and correct. Machining something sticking only a little way out of the machine vice and overhanging the side of the VS table, the whole lot is liable to move, requiring excessive clamping pressure. Myfords introduced a newer version with a pair of tee bolts side by side on both swivels to reduce amount of tightening but increase the grip and so prevent unintended movement. I also have one of these later types and can confirm their superior design. Dont plan to sell either at present even though I rarely have use for them as I have since obtained a mill with H + V capability. Nothing wrong as such with yours but only light cuts over say 2" radius from vert. screw. You could experiment with a slip of dry (not oily) paper under each joint.
Edited By DMB on 08/11/2013 15:55:13
Harry Wilkes09/11/2013 14:28:49
1613 forum posts
72 photos
Hi John
Thanks for your reply, the point I was trying to make if that the holding down bolt on mine is not as the picture and I feel that in order to pass it through the tube which clamps the swivel makes it quite thin and flimy so I would rather replace it with the proper designed bolt ! So if some kind gent could draw up the bolt and email it to me wink
Cheers H
Ziggar09/11/2013 17:09:47
115 forum posts
just make one to fit.........
don't need a drawing
i just did the exact same thing when i acquired one without the bolt and bottom swivel, simply made them to fit
Z
NJH09/11/2013 18:53:00
2314 forum posts
139 photos
Hi Harry
The original slide is as you have pictured in your post.
The revised one is here:-
Underside
and disassembled
If you want any dimensions just send me a pm - fairly soon whilst I still have it in bits! ( At the moment it's on the hall table and I'm taking a bit of a chance that my ever loving will not complain for a while)
I did have a "Mk1"  vert. slide some years ago but sold that with a previous lathe - I suspect that the "T" bolt is similar ( certainly the T part will be) but the length might be different.. What length do you think yours requires?
Norman
Edited By NJH on 09/11/2013 19:01:36
John Haine09/11/2013 23:21:04
5563 forum posts
322 photos
Harry, pm me your email address and I can send you some photos I took this evening of the bolt off mine which will give you the dimensions. Trying to use this site to transfer them is making me lose the will to live.
Ady110/11/2013 01:27:58
6137 forum posts
893 photos
Make one to fit and make it as chunky as possible
The original T on the t-nut is a bit mincy and you need as much stiffness as possible when milling on a lathe
It's also worth bolting an extra hard point against the side of the milling base, (bolted to the cross slide and pushing against the side of the milling slide), this helps to prevent any movement with the single bolt slides, they can swivel under pressure if there isn't any additional support
The second photo shows the two t-nuts of the "improved" version which helps to prevent this twisting weakness the single t-nut version suffers from
Edited By Ady1 on 10/11/2013 01:40:58
Harry Wilkes12/11/2013 03:03:05
1613 forum posts
72 photos
Many thanks for all comments, John have sent PM
H
John Haine12/11/2013 19:56:35
5563 forum posts
322 photos
Harry, was that John me? No pm received yet...
Harry Wilkes12/11/2013 22:07:26
1613 forum posts
72 photos
Posted by John Haine on 12/11/2013 19:56:35:
Yes John I will resend it
H
John Haine12/11/2013 23:16:19
5563 forum posts
322 photos
Mail just sent.
