michael burton 1 | 07/10/2013 20:36:58 |
126 forum posts 32 photos | hi can a steam cylinder be made out of aluminium i would be using a bronze liner obv car and bike engines are made out of aluminium but i was worried as to slide valve surface being ally and what type of meterial i should use for said valve. im going to the metal supplie shop tomorow and was gunna try to pick up some of the material i need the reason for using ally was i need a block 3.5'' square and it was the cheapest route cheers for any help |
JasonB | 07/10/2013 20:54:46 |
![]() 25215 forum posts 3105 photos 1 articles | Is this for your traction engine? If so I would tend to say no, if just for a little stationary engine then yes I'd go for a block of cast iron, cost about £5 more than aluminium but you would save on the cost of the bronze liner. Edited By JasonB on 07/10/2013 20:55:27 |
michael burton 1 | 07/10/2013 21:39:58 |
126 forum posts 32 photos | hi yes it for the traction engine the only reason i was going to use the liner mainly was because on the plans for the smaller version that i have scaled up used a wastited cylinder linder around the outside to direct the steam up in to the regulator chest i supose tho with abit of thinking i could redsign it to do away with this part and reposition the steam ports
JasonB | 08/10/2013 07:31:42 |
![]() 25215 forum posts 3105 photos 1 articles | Its more a problem of corrosion that I was thinking of. If your design is steam jacketed then you can still do it with a CI block and CI liner which will still be cheaper than ali/bronze. This one of mine is an iron casting with a liner cut from iron bar. You can do it by drilling two steam passages to get around the cylinder but the heating effect of the jacket is helpful. |
Geoff Rogers | 08/10/2013 11:51:17 |
30 forum posts 4 photos | as JasonB says, corrosion would also be my main worry. Some aircraft grades of aluminium may be ok, others most definitely not. Steam can be a very demanding fluid.
fizzy | 09/10/2013 00:08:19 |
![]() 1860 forum posts 121 photos | to be frank - yes, no problems. Sure it will oxidise, but do you realy intend on running it for the next 120 years...thought not. Having said that, i would opt for cast! |
JasonB | 09/10/2013 07:41:55 |
![]() 25215 forum posts 3105 photos 1 articles | By corrosion I was thinking more along the lines of galvanic/catalitic attack being bolted to a copper boiler with bronze fixings all in a damp warm enviroment, rather than surface oxidation |
