Chuck repair help needed
mathsman04/10/2013 00:07:52
4 forum posts
After speaking to the chuck man at Pratt Burnerd ( David Stanley ) about my ancient 6" independent 4 jaw, I was directed to "Rotagrip" for replacement operating screws.
The price of a couple of new adjuster screws from Rotagrip would buy me a new Chinese chuck !!!!
What is going on?? Does Rotagrip by any chance have new mandarin speaking owners trying to increase their trading share??
Or is it just good old ripoff Britain pricing itself out of the market???
Can anyone suggest a source of operating screws at a sensible price ?
Thanks
daveb04/10/2013 00:36:38
631 forum posts
14 photos
It's only a screw. Isn't this the sort of thing you make on a lathe?
I modified some 1/2" BSW Allen grub screws to replace the screws on my Pratt 4" chuck, has anyone made new screws to suit the 6" chuck?
Dave.
Robbo04/10/2013 09:56:12
1504 forum posts
142 photos
New screws can be made from 1/2" grubscrews as Dave suggests, there was even an article about it in a MEW, whose issue number I forget. I think the screws are the same on both 4" and 6" chucks, but will check.
Of course the grubscrews will have a hex hole in the end, not a square one, so either make a set of four or have two keys.
I can look up the MEW issue if you want, and copy you the article. May even have a few grubscrews left
Phil
colin hawes04/10/2013 11:08:04
570 forum posts
18 photos
These screws usually break across the square hole when the chuck key is used to unscrew the chuck. I have repaired two or three by welding. Hint :a square aluminium plug can help stop weld metal obstructing the hole. Colin
jonathan heppel04/10/2013 13:35:27
99 forum posts
Don't blame Rotagrip. Their prices just represent the true cost of pro grade industrial kit, though I wouldn't be hugely surprised if the Pratt screws come from the same factory as the cheap ones.
As for using a chuck key to remove a chuck, well..............
Robbo04/10/2013 13:48:30
1504 forum posts
142 photos
Got it wrong there I'm afraid - have to go to Specsavers again. The screws on the 6" chuck are much bigger, probably a nominal 3/4", but the thread is 8tpi, so does'nt match up with a BSW form, which would be 10 tpi for this dia..
The only problem with making them from bar is making the square hole in the end.
Phil
mathsman04/10/2013 15:55:50
4 forum posts
Thanks for the input guys, biggest problem is that my lathe is non screw cutting and hence very limiting.
I'll try the grub screw idea if I can obtain, say, hex socket heads with same/similar thread ( pigs might!! ).
Unfortunately the northeast is not over endowed with engineering suppliers so Google is in for some overtime.
Thanks to all.
Alan Girvan05/10/2013 11:58:00
40 forum posts
I think my chuck is the same as the one you have, same name, same size. One or two were broken on my chuck I could not source new ones so i decided i would have a go and make some. I made 5 and found they worked well so I have one left and three old ones left which seem servicible. you can have them for cost of postage. The size of screws just under 2.5 inches long 8 theads tpi. The thread is left hand and the chuck key is 8hex.
If you would like to try them and then decide you would like me to make you some I can do so for a small cost.
Regards, Alan.
mathsman06/10/2013 20:10:42
4 forum posts
Alan, that sounds a good deal to me, thanks.
I've replied via "Message member" but the forum reply system doesn't confirm whether or not my message got to you, hence this "public" posting. Hopefully we can establish contact.
mathsman
JasonB06/10/2013 20:50:53
Mathsman if you look in your to your inbox (Top green bar on page), then select sent box it will either say "unread" against the message or the date and time it was read.
J
Edited By JasonB on 06/10/2013 20:51:26
Alan Girvan07/10/2013 18:59:43
40 forum posts
Hi, I have sent you a message to see if you get it as i didn't receive anything from yourself. I can see it is currently sitting as 'Unread'.
Hopefully you will get it and then we can exchange details.
Alan
Nigel McBurney 121/10/2013 17:59:00
1101 forum posts
I have found Rotagrip very good to deal with,and very knowlegeable,dont blame them for Pratt burnard prices,Pratts spares have always been very highly priced,
