Boxford 8" Shaper
Adjustment of drive gear
Gray6209/09/2013 19:41:44
1058 forum posts
16 photos
I recently acquired an 8" Boxford Mk2 shaper, in excellent condition although the meshing of the drive pinion with the crank gear is a little 'loose' for want of a better description.
The manual states that this meshing can be adjusted by means of the gear shaft eccentric.
The manual does not however, illustrate or describe how this adjustment is achieved.
Do any owners of this machine know how this adjustment is carried out?
cheers
Graeme
John Baguley09/09/2013 22:10:08
517 forum posts
57 photos
Hi Graeme,
I didn't realise the meshing was adjustable until you mentioned it! I didn't touch the bush when I rebuilt mine.
Looking at the drawings I have, the bush for the drive axle is indeed eccentric. If you take the drive pulley off, the bush is fastened to the main casting with 3 clamps with 2BA bolts. If you loosen those bolts you will be able to rotate the bush and so adjust the mesh.
Hope that helps,
Edited By John Baguley on 09/09/2013 22:14:44
OuBallie10/09/2013 10:36:37
1181 forum posts
669 photos
Thanks for that John.
News to me!
Must check my Boxford now.
Geoff - One of the reasons I joined this forum - useful info!
Gray6228/10/2013 16:06:14
1058 forum posts
16 photos
Does anyone have any details/drawings etc of the optional vertical feed mechanism that was fitted to some of the later underdrive Boxford shapers?
According to lathes.co.uk - When fitted with power vertical feed, the operating mechanism was cleverly designed to allow its pawl and ratchet assembly to be swung through 180 degrees to engage either movement.
Mine looks to have been prepared for this in that it has the indexing gear fitted to the vertical movement drive shaft but some of the mechanism seems to be absent.
Failing this I can feel an adventure into a CNC'd machine taking shape (Pun intended)
CB
Saxalby28/10/2013 16:44:56
187 forum posts
33 photos
Hi CB,
I can photograph the mechanism on my one if that will help.
Regards Barry
Gray6228/10/2013 18:41:10
1058 forum posts
16 photos
Hi Barry,
Any info will be appreciated, photos are great,
many thanks
Graeme
Saxalby28/10/2013 20:07:03
187 forum posts
33 photos
Hi Graeme
Found this diagram of the horizontal power feed.
This shows the additions for vertical feed
Ratchet wheel and spur gear are keyed / pinned together but not to the horizontal feed shaft.
Hope this helps - Barry
Gray6229/10/2013 11:48:39
1058 forum posts
16 photos
Hi Barry,
Many thanks that info is great, where did this info come from? I have the manual but it doesn't give this type of info
regards
Graeme
Saxalby29/10/2013 13:37:35
187 forum posts
33 photos
Graeme,
Got the diagrams from the Boxford web site, under their spares listings.
Barry
