warco vmc motor wire connections
vmc motor wiring
kevin simmonds13/08/2013 20:21:23
3 forum posts
I recently inherited a warco VMC MILLING MACHINE manufactured 2011. In an effort to move the mill I removed the head from the mill and disconnected the motor. I thought it would be a good idea to take a picture on my phone so it could be easily re connected. Unfortunately I lost my phone. Warco aren’t able to give me a wiring diagram with the wiring connections on for the motor which seams hard to believe and is a bit disopointing.
There are 4 wires and an earth wire which are labelled L11, N11, Z1 AND Z2
The connector block inside the motor has six terminals
Top left Z2/W2 , U2, V2
Bottom left U1, V1, Z1/W1
The motor is a dual capacitor induction motor model YL90L-4 /240 V/ 1400 RPM/ 1.5 HP
If anyone has a warco with the same motor and would not mind taking a look under the motor cover I would be most grateful
Kevin
Springbok14/08/2013 03:35:31
879 forum posts
34 photos
Hi Kevin
Look at
grizzly.com
your machine will be under a different name but they write there own manuals and are free downloads.
good luck
Bob
Mike Poole14/08/2013 07:22:40
3676 forum posts
82 photos
Hi Kevin,
I have the same mill with that motor type. I have 2 red wires labeled Z1 and Z2 and 2 black wires labeled U1 and U2. Z2 goes on the top left U2 on top middle U1 bottom left and Z1 bottom middle.
kevin simmonds15/08/2013 00:18:54
3 forum posts
A big thankyou to Bob and Mike my machine is now working at last
Has anyone experienced vibration on there VMC machine? i am getting a pulsing vibration once per revolution so i am wondering how good the bearings are in the motor. I do have the machine straght on to concrete should i isolate it with rubber? any suggestions
kevin
maurice eley21/03/2016 11:20:20
1 forum posts
Has any one made a riser block ie 4" tall for a Warco VMC mill >? Do you have any drawihg /dimensions please
Vic21/03/2016 11:48:31
3453 forum posts
23 photos
Posted by maurice eley on 21/03/2016 11:20:20:
Not made one myself but others have and there are drawings on the net somewhere. The topic was also covered in a fairly recent edition of MEW. Shame Warco don't make one really as I'd like one but my Lathe isn't really big enough.
Roger Vane21/03/2016 12:53:33
108 forum posts
18 photos
Maurice
After pestering Roger Warren of Warco on a number of occasions - unsuccessfully - I decided to make my own 4" raising block for my VMC.
I described this in MEW issue 215 onwards. It can be machined (with care) on a Myford Super 7, although you will need a threaded 4-jaw chuck to manage this. As well as drawings, the article details the machining process used (with photos of the set-ups). It also emphasises the care required when machining such a large lump of cast iron.
The raising block has proved to be very successful in use, really changing the machine for the better, with lack of headroom never now being a problem. The only problem that I have experienced is that when raising the knee to the maximum as a test, the vertical leadscrew became disengaged, and it's not easy to re-engage - so beware.
Hope this helps.
John Stevenson21/03/2016 13:10:55
5068 forum posts
I have done 3 or 4 Warco, Chester, and those people in Wales who's name escapes me,
Problem is all of them have had different registers. The last one I did was 79.86 which I believe differs from Rogers.
Just checked MEW215 and Roger has 3.307 in old money or 83.99 and that was also a Warco
Rogers bolts were 3.985 between centres [ 101.22 ] mine were 72.72
