Member postings for kevin simmonds
Here is a list of all the postings kevin simmonds has made in our forums. Click on a thread name to jump to the thread.
Thread: warco vmc motor wire connections
15/08/2013 00:18:54
A big thankyou to Bob and Mike my machine is now working at last
Has anyone experienced vibration on there VMC machine? i am getting a pulsing vibration once per revolution so i am wondering how good the bearings are in the motor. I do have the machine straght on to concrete should i isolate it with rubber? any suggestions
kevin
13/08/2013 20:21:23
I recently inherited a warco VMC MILLING MACHINE manufactured 2011. In an effort to move the mill I removed the head from the mill and disconnected the motor. I thought it would be a good idea to take a picture on my phone so it could be easily re connected. Unfortunately I lost my phone. Warco aren’t able to give me a wiring diagram with the wiring connections on for the motor which seams hard to believe and is a bit disopointing.
There are 4 wires and an earth wire which are labelled L11, N11, Z1 AND Z2
The connector block inside the motor has six terminals
Top left Z2/W2 , U2, V2
Bottom left U1, V1, Z1/W1
The motor is a dual capacitor induction motor model YL90L-4 /240 V/ 1400 RPM/ 1.5 HP
If anyone has a warco with the same motor and would not mind taking a look under the motor cover I would be most grateful
Kevin
Thread: My New Warco VMC Turret Mill
11/08/2013 13:09:14
Hi I recently purchased a second hand Warco VMC which was manufactured in 2011. I removed the head/Motor for transportation but unfortunately lost the piece of paper with wiring connections on. The motor is a single phase double capacition induction motor.
The terminal block inside has on the top row left to right connections
Z2/W2 next U2 next V2
bottom row lower left U1 next V1 next Z1/W1
The wiring to the motor has the following labels attached.
Red wire Z1 Red wire Z2 Black wire n11 Black wire L11 and an earth wire which has an obvious position on the motor.
I contacted Warco and they sent me a circuit diagram it had no reference to the connection on the motor. Can anyone help????
