A variable Lead threading attachment. Author Ted McDuffie
Article in MEW ??? published Autumn 1990
Brian Wood03/06/2013 18:53:48
2742 forum posts
39 photos
Some help please with Mr McDuffies article which was published in MEW in the Autumn edition 1990, before the time I started taking the magazine.
My interest stems from Theodore Clarke's artic;le in MEW 204 [ the current issue] which refers to Mc Duffies work as a reference; it would make useful background reading on what seems to be an interesting method of altering thread pitch.
Can any of you help please with a back copy or similar?
Thank you
Robin King03/06/2013 19:21:54
137 forum posts
If you've managed to log in to post this message presumably you can also access the digital edition, issue 2 on the last page of the digital listing - would that help?
Robin
Brian Wood03/06/2013 19:30:00
2742 forum posts
39 photos
Hello Robin,
Thanks for the suggestion but don't I have buy into the digital issues first? And in any event I am missing the actual issue number to look for as well.
I'm not being deliberately mean, I already pay for my copies at subscription rate
JasonB03/06/2013 19:44:28
If you have a paper subscription to MEW then you can view MEW back issues on line, if you get it from newsagent etc you can't.
Its issue No2.
Brian Wood03/06/2013 19:47:24
2742 forum posts
39 photos
That's very helpful Jason, thank you.
Stub Mandrel03/06/2013 20:56:34
4318 forum posts
291 photos
Brian,
You need to enter your subscriber number on your profile page before you can access your digital issues.
Robbo03/06/2013 21:30:10
1504 forum posts
142 photos
Brian,
If you're not a subscriber but an "over the counter" reader of MEW, I can send you a digital copy of the article.
Phil
Brian Wood04/06/2013 09:48:10
2742 forum posts
39 photos
Gentlemen,
Thank you one and all for the sage advise. I do pay for postal subscriptions but I usually dump the wrapper which has the Sub. number on it; this time I need it!! Ah well, there's no rush, I now have the information I needed to retrieve that particular article
Phil. Thank you very much for your generous offer, it is greatly appreciated but I hope I can work the digital method satisfactorily. My suitably aged grandson lives in the USA so I shall have to muddle through; it doesn't come as easily to me as making swarf and failures.
If all fails I will knock on your door.
Thanks again to everyone
Robbo04/06/2013 23:02:21
1504 forum posts
142 photos
Brian,
Forgot to say in previous post that I have all the paper copies of MEW, so can just scan several pages into one file.
As my wife would say "silly old fool" I wish she wouldn't call me old!
Phil
Brian Wood05/06/2013 08:54:24
2742 forum posts
39 photos
Hello Phil,
I get the same sort of disrespectful comment, it depends on the crime of course but "daft old bu**er" gets used for serious offences!.The 'old' bit does grate doesn't it.
Thanks again for your support if I need it.
Best wishes Brian
jacques maurel06/06/2013 21:04:04
84 forum posts
20 photos
I've published a "universal threading attachment" almost completely contained on a toolholder, based on Thales theorema, point E being fixed and BC being adjustable:
jacques maurel06/06/2013 21:06:18
84 forum posts
20 photos
This was in ME issue 4270 (march april 2006) general view:
jacques maurel10/06/2013 22:52:25
84 forum posts
20 photos
There are numbers stamped on the lever and charts are given so it's easy to cut any lead. On the photo (metric lead screw) one side of the groove is graduated for imperial leads, the other for module leads (for cutting single start worms). No change gear is needed, all cutting is from the standard gear box but the thread must be short (50 mm) read the article for details.
Gary Wooding11/06/2013 14:54:51
1074 forum posts
290 photos
I don't take ME, so could you make details available on this forum, or maybe email to interested parties?
jacques maurel12/06/2013 15:10:46
84 forum posts
20 photos
The calculation is BC = 30/(p'/p-1) mm, p' being the lead to obtain and p the standard one.
Ex for p' = 20 TPI (1.27mm) and p = 1mm, BC = 111 mm (position 2).
The charts and graduations are here to help when setting the lathe for standard leads (imperial and module for a metric lead screw, metric and diametral pitch of an imperial one).
Almost any lead can be obtained within the range of the lathe gear box.
My attachment is quickly set up (contained on a toolhoder). Because for me the time for removing and resetting the top slide, is the same as the time for setting and resetting the banjo arm.
Ex : chart for machining module leads from a metric lead screw:
Brian Wood13/06/2013 08:36:24
2742 forum posts
39 photos
Hello Jacques,
I have been busy elsewhere since my posting on 5th June, you have added helpful information and some detail to flesh out the story and extend the understanding a trifle. Thank you
Gary Wooding
If you want a copy of the Mc Duffie article that I started this thread with, send me a PM with your email address, I can now copy one to you.
jacques maurel15/06/2013 16:19:56
84 forum posts
20 photos
With the universal threading attachment (and the others variable lead attachments) it’s possible to use the “Thread dial indicator”, so it’s possible to open and close the “Half nuts”,(as you are using a standard thread from the gear box). This makes thread machining far easier!
It’s possible to work against a shoulder from left to right as described in this video:
jacques maurel15/06/2013 16:40:26
84 forum posts
20 photos
This link will work :**LINK**
Stub Mandrel15/06/2013 19:02:58
4318 forum posts
291 photos
But are the errors ever big enough to need this level of correction? Only for leadscrews or similar.
A 1% error in an M6 thread would amount to about 0.05mm over the thickness of an M6 nut. Smaller than the production tolerance, and as good as a die-cut thread.
jacques maurel15/06/2013 23:59:18
84 forum posts
20 photos
The purpose of this attachment is not to correct the lead but to use the standard gear boc leads for machining any odd lead, so no change gear is needed (only the standard gear box is used).
Of course there is some geometric error as the linkage goes away, but for about 50mm long (short thread) this is negligeable (less than the lead screw error).
