Notlob | 29/05/2013 15:45:06 |
6 forum posts | I have a warco vmc milliing machine. The problem is on this machine is the spindle b e locked, my er32 chuck just rotates with the spindle.. Anyone gt any solution to this. Edited By Notlob on 29/05/2013 16:17:11 |
Chris Heapy | 29/05/2013 15:54:15 |
209 forum posts 144 photos | There should be a hole in the body of the chuck to accept a bar - I use a screwdriver pushed through. Hold it with that whilst you tighten the nut. |
joegib | 29/05/2013 16:15:43 |
154 forum posts 18 photos |
Posted by Chris Heapy on 29/05/2013 15:54:15:
There should be a hole in the body of the chuck to accept a bar ... — or 2 flats on the chuck body to take a spanner. You hold that element with one spanner and tighten the nut with another spanner (either a conventional spanner if the nut has flats or a C-spanner if it has notched indents). Come to think of it, machine spindles that have a locking mechanism are the exception rather than the rule. Joe Edited By joegib on 29/05/2013 16:19:48 |
JasonB | 29/05/2013 16:18:36 |
![]() 25215 forum posts 3105 photos 1 articles | Or a knurled ring on the holder body which you hold with one hand and a C spanner on the nut which is what I have.
J |
Notlob | 29/05/2013 16:20:24 |
6 forum posts | The chluck body has no flats, it is just round And my bridgeport the spindle can be locked
Edited By Notlob on 29/05/2013 16:21:52 Edited By Notlob on 29/05/2013 16:35:12 |
Les Jones 1 | 29/05/2013 16:39:12 |
2292 forum posts 159 photos |
Hi Notlob, Les. |
Windy | 29/05/2013 16:42:52 |
![]() 910 forum posts 197 photos | I have a Warco VMC with a ER32 chuck supplied by them and no means to lock it when tightening the nut. It is not like a Vertex one I have with spanner flats (different taper) I used a carbide end mill to create some spanner flats on the Warco ER32 chuck. Paul |
Notlob | 29/05/2013 16:49:10 |
6 forum posts | And I was a toolmaker for 35 years
Notlob | 29/05/2013 17:03:46 |
6 forum posts | When I pointed this out to Warco their reply was ther is no way to lock the spindle so tough
Tony Pratt 1 | 29/05/2013 17:36:49 |
2319 forum posts 13 photos | On my Myford VME vertical milling m/c there was no means of locking the spindle so I made one! Underneath the large front pulley there are a series of what I presume are balancing holes, it was a simple matter to knock up a block and sliding pin to locate in one of these holes whilst tightening the draw bar. It may be that the Warco VMC has something similar? Tony |
Notlob | 29/05/2013 18:37:12 |
6 forum posts | I probably will have to buy another collet holder one with spanner flats |
Old School | 29/05/2013 20:00:37 |
426 forum posts 40 photos | Notlob, You should be able to hold the spindle with an oil filter type wrench with a rubberised fabric strap. |
Trevor Drabble | 29/05/2013 20:24:43 |
![]() 339 forum posts 7 photos | Notlob, I faced exactly the same problem as yourself with my ER32 holder, but since one of the reasons I chose my Myford VMB milling machine was because of the 3000 RPM top speed, the solution was relatively simple. I modified an R8 stub arbour to accept a grinding wheel I had in stock , then set up the collet holder vertically onto an angle plate on the milling macine table, protected all exposed machined surfaces, installed a front safety guard for myself, and then, ensuring I was below the MOS, ground a pair of flats on the holder body to suit a Clarkson collet chuck spanner I had in stock.. One thing I did particularly ensure was that I only presented the holder to the wheel AGAINST the direction of rotation since I did not want it to grab. Hope you will find this info of some use. Trevor. |
Gone Away | 30/05/2013 02:07:54 |
829 forum posts 1 photos | My ER-25 chuck has the same problem. At the top of the mill there is a tubular nut with flats on it that the drawbar jacks against when releasing. I used to do that nut up as tight as I could and hold it with a wrench when tightening/loosening the collet nut. That was OK when tightening the collet nut of course. As with all my ER chucks, I don't overdo the chuck tightening - just a little nip - nonetheless at intervals when loosening the collet nut, the top nut would loosen and I'd have to remove the whole chuck and put it in the vice with soft-jaws to undo it. Then I bought an ER-32 chuck which had proper flats on it which I prefer anyway since the size range suits me better and I rarely use the ER-25 any more. Edited By Sid Herbage on 30/05/2013 02:08:40 |
Stub Mandrel | 30/05/2013 19:19:22 |
![]() 4318 forum posts 291 photos 1 articles | is the body of your chuck hardened? If not, why not drill three holes for a tommy bar? If it is hard, a carbide drill might still drill it. Neil |
