Qualters and smith
andrew bunn | 20/05/2013 12:08:00 |
3 forum posts | Hello I have just salvaged a Qualters and Smith 6" power hacksaw. It seems to be in good condition. However the Motor is missing. I know these machines are wired for 3 phase but could anybody tell me what size the motor would normally be and what the outside diameter of the drive pulley ? I would like it to cut about 100 strokes a minute if possible. Thank you |
Ian S C | 21/05/2013 12:54:50 |
![]() 7468 forum posts 230 photos | 100 per min a wee bit fast, I'd look at about 80. You'd be OK with a 1450/4 pole half horse power single phase motor. Ian S C |
andrew bunn | 21/05/2013 17:04:17 |
3 forum posts | Thanks Ian Any idea about the size of the pulley I should fit . The driven pulley is 240mm or 220mm. I was thinking of something around 70mm to 85mm Thanks |
Clive Foster | 21/05/2013 23:21:49 |
3630 forum posts 128 photos | For what its worth my Vee belt drive Manchester Rapidor has a two stage reduction coming out around 13 or 14 to 1 reduction. Approximate pulley diameters are 80 mm on motor and intermediate shaft, driving 260 on the intermediate and 300 on the saw crank. Wave a tape at it guesstimate as the saw sits at the end of my big lathe and I'd need to pull it out and unhitch a cover to measure properly. When you get it going do remeber to bolt it down as they tend to wander around a bit if unrestained. The Rapidor moved a couple of inches per hour of operation on a smooth "underfloor boarding" floor before being restrained. Clive |
_Paul_ | 22/05/2013 01:48:14 |
![]() 543 forum posts 31 photos | Well done they are good robust machines but a little on the heavy side. You will find 1/2 HP is not enough it may turn the machine over but the cut speed will drop under load. My 6" Qualters & Smith has a 1&1/2 hp 1425 rpm? single phase motor and cuts well with it, I will check the pulley sizes for you tomorrow. Once I can find the manual I can tell you what the recommended cut speed is. Regards Paul |
bebo bebo | 23/05/2013 06:03:02 |
2 forum posts | I have no Idea about t the size of the pulley of this. |
andrew bunn | 23/05/2013 10:03:08 |
3 forum posts | Hi Thanks to eveybody who posted help. I have got a 11/5 hp motor single phase motor but its base foot is 100mm between centres so I will have to make an adaptor plate because the casting mounts on the saw are 80mm between centres.
oldvelo | 24/05/2013 02:55:27 |
297 forum posts 56 photos | Hi Andrew Trolled up a bit of info on Qualters And Smith Power Hacksaws. The Bulldog 150 can be viewed working here-
http://www.youtube.com/watch?v=isuPXWE1wyM |
Ian S C | 24/05/2013 14:23:38 |
![]() 7468 forum posts 230 photos | My 80 strokes was without coolant fluid. Ian S C |
