cutting internal gear rings
rebekah anderson14/05/2013 15:47:44
135 forum posts
hiya every one.
I was wondering if any one knew how to make a cutting tool in order to cut teeth in an internal gear ring.
the sort of sizes I'd am looking at is as small as 25mm internal diameter of the ring. the cutter would need to be accompanied with a normal gear cutter to marry up with the internal gear ring.
I have seen the keyway cutter divice that mounts on the myford and the like. which is something I'll have to make, unless there is one out there for sale.
any help would be greatfully recieved.
in the mean time, what is the opinion of the Myford ML2 for small hobby work.
regards
Becky
magpie14/05/2013 17:00:40
508 forum posts
98 photos
Hi Becky, Do you realy need to make the ring gear and pinion yourself ? I have some small ex WD motors that have a planetry gearbox on the end. The inside of the ring gear is about 23mm. one of these motors with gearbox could be yours for £5.00 plus postage. they are a really nice bit of tackle, so i will put a photo in my album. The ring gear is the one in the middle of the pic an has six mounting holes around the edge,and the planet gears (3 of them) are shown on a carrier. If they will do the job send me a PM. Cheers Derek. P.S. sorry the photo is a bit hazy.
rebekah anderson14/05/2013 17:08:56
135 forum posts
Looks pretty good but i need to make my own. As there are a variety that i need to make.
Applications are the slew gear for a hiab crane, drive gear for the sprockets on a digger.
So really would like the tools to make them.
Brian Wood14/05/2013 17:23:49
2742 forum posts
39 photos
Hello Becky,
I inherited my father's ML4 which superceded the ML2 and did a lot of work with it. If you can find a nice one at a reasonable price and complete, there is no reason why you shouldn't be completely happy with it.
One modification I would recommend would be to make and loctite on a close fitting collar for a chuck register of ML7 Myford size [ie 1.250 inch diameter] Complete the turning with it installed to keep things absolutely true and concentric. You may have to use a little ingenuity to get turning tools to reach that close to the headstock.
You will then be able to fit readily available Myford fitting chucks and faceplates without searching for the smaller and scarcer 1.125 inch versions that the spindle was made for
I found that very worthwhile on Dad's lathe and altered the chucks that came with it to fit the new size
Happy turning
rebekah anderson14/05/2013 17:32:03
135 forum posts
Thank you for the tip. I'll look into applying the mod.
I've got a sieg C3 at the mo but just wanted something more for my work.
This is what i bought.
http://s526.photobucket.com/albums/cc346/rebekah3505/?action=view&current=8bf5b9dccff8cd5b0ff17274a0ce650e_zps29ae724d.jpg
Edited By rebekah anderson on 14/05/2013 17:33:10
JasonB14/05/2013 17:45:35
If you can draw out the gear profile then grind a tool to that shape and use the planing method in the lathe, you don't need the straking tool it can be done by using the carrage handwheel, the setup would be similar to this
The other way is to make a broach similar to a spline broach which is pushed through a ring cutting the teeth as it goes
Edited By JasonB on 14/05/2013 17:46:24
rebekah anderson14/05/2013 17:53:30
135 forum posts
That's the sort of tool i'm looking for.
Not sure how to make it though.
the broach is out of my league lol
Michael Cox 114/05/2013 18:35:22
555 forum posts
27 photos
Hi Becky, I do not know what material is necessary for your part but if plastic were acceptable then have a look at madmodder.net and search for "forming plastic gears.
The method, as shown is used to form external gears but I cannot see why it would not work to form internal gears.
Edited By Michael Cox 1 on 14/05/2013 18:37:17
Brian Wood14/05/2013 18:36:16
2742 forum posts
39 photos
Hello Becky,
That is a nice looking lathe, did it look that that when you bought it? Was backgear an ML4 addition?
JasonB14/05/2013 18:40:42
Becky, the tooling is quite easy to make. You just need a short length of bar say 1/2" dia, cross drill the end say 1/8" to take a HSS tool bit or even a broken centre drill and at right angles to that hole drill and tap for a grub screw.
The screw can alternatively come in from the end
You then just need to have a way to index the work for the number of teeth you require, move the carrage back and forth feeding in say 0.005" at a time until the tooth gap is formed, rotate round to the next one and repeat. These three took me about 60secs.
I notice from your album you do a lot of work in Aluminium, I would suggest brass for the gear as its easy to work, those ones needed hardly any effort to cut. You just need to grind the end of the cutting tool to match a printed out profile of your gears.
You can also use the same method to cut keyways if you do't have a suitable broach, just grind up a square ended tool
J
Edited By JasonB on 14/05/2013 18:45:43
Michael Gilligan14/05/2013 18:43:47
23121 forum posts
1360 photos
Becky,
For an alternative approach; have a look at the HCF and UCF on this page.
If you are using Brass, Aluminium, or Plastics for the Gears then ... Set up with a suitable cutter, these have the potential to do what you need.
Bazyle14/05/2013 18:45:12
6956 forum posts
229 photos
The way to do it is to first think how you would make a normal gear of that size that would fit inside your internal gear with the same number of teeth ie filling it entirely like a splined shaft.
Then if you were to make that gear with just one tooth (and most of it's body not there) then that tooth is the cutter you want.
Plenty of articles in ME and on the web about how to make the normal gear cutter using two discs of appropriate size & spacing - it is just adding an extra stage to sequence.
Make tool
Make cutter
make single tooth gear
turn 'gear' into cutter
cut internal gear.
If you photograph your stages it would make a nice little article.
rebekah anderson14/05/2013 19:00:43
135 forum posts
Wow guys,
i was trying to thank every one induvidually but the influx of info was overwhelming.
Material of aluminium or brass. So i will give the brass a go first. Great info for making the tool. I think i will combine the two main methods on here.
As for the lathe, got to be joking, bought it like that. I am decent machinist but that's way beyond me lol. I think i got an absolute bargain (well i hope) i just needed a more capable machine as the detail I am moving is getting more important. Add to this i got to learn how to get decent internal thread done too. This is for 6mm hydraulic cylinders.
Thank you every one.
You have inspired me for the tool and will be getting on to it in the next couple of weeks.
Andrew Johnston14/05/2013 19:38:40
7061 forum posts
719 photos
I'm afraid that the method suggested by Bazyle will not give you the correct form for an internal gear tooth. The tooth spaces of an internal gear are not the same as the tooth spaces of an external gear. The design of tooth spaces for internal gears is significantly more complicated than the simple rules for external involute gears.
The practical complexity depends upon the DP and number of teeth on the internal gear. One general rule is that for gears of 4DP and finer, and more than 60 teeth, a number 1 cutter can be used, ie, one intended for external gears of 135 teeth to a rack. I suspect that this might cover the slewing gear, and you could probably get away with a cutter tapered at the pressure angle of the gear, with no curves. However, as the number of internal teeth get smaller, and the external pinion gets bigger as a proportion of the internal gear, then all sorts of 'fiddle' factors are involved to allow for interferences between the teeth.
For the smaller internal gears there is probably not much point in calculating the exact internal tooth forms, as I assume it would be difficult to make a small tool of the correct shape in the home workshop. A pragmatic approach would be to draw a few teeth at a large scale on graph paper and play with a few simple tooth shapes that avoid interferences while allowing a tool to be simply made.
Or buy a copy of Gearotic!
