Expanding worn pistons
Windy | 16/04/2013 16:56:45 |
![]() 910 forum posts 197 photos | I am not sure if it was this forum but there was a thread explaining about how to increase worn cast iron piston dimensions with heat. Could some one advise me about using this method please? Paul
Edited By Windy on 16/04/2013 16:57:05 |
john kennedy 1 | 16/04/2013 18:22:10 |
![]() 214 forum posts 24 photos | Windy, I remember reading about that process on here. **LINK** Try doing a search. John |
Francois Meunier | 16/04/2013 21:27:01 |
30 forum posts 6 photos | upon heating to red and quenching in oil, your worn piston do hardly enter in the cylinder, amazing, it gives some meat to lap again, the increase in dia was about 0.02 mm for a 25 mm piston, but not not regular, more pronunced on the lower, thinner part, somewhat oval too..., may be not quenched properly. Zephyrin Edited By gedeon spilett on 16/04/2013 21:28:25 |
Stub Mandrel | 16/04/2013 21:30:52 |
![]() 4318 forum posts 291 photos 1 articles | Hi Windy, Its been mentioned in ME. As I recall you soak it at red heat for a good while as if you were normalising it and add a thou or two per inch, then re-lap it. Obviously you can only do this once. Neil I found this - makles it nice and simple, eh? " Irreversible Carbon Diffusion in Growth of Cast Iron1984 MRS Fall Meeting.K. Nagaokaa1 and M. Soumaa1a1 Faculty of Eng., Hokkaido University, Kita 13 Nishi 8, Kitaku, Sapporo, 060, Japan ABSTRACT In gray cast iron carbon diffuses irreversibly and the result is a growth remaining castoff voids and graphite redistribution. The origin of primary growth is in the mechanism of carbon diffusion which is controlled by a ratchet at graphite where carbon is carried by vacancy flow. Growth of flake cast iron in oxygen reduced air at low oxygen content is accounted for by self carburizing due to a reaction of penetrated oxygen and graphite flakes. For the irreversible carbon migration by gaseous carrier another ratchet is suggested. Cracking theory for primary growth is replaced by castoff void theory, and oxidation theory is modified." |
Paul Lousick | 16/04/2013 22:48:12 |
2276 forum posts 801 photos | Try this link for making piston rings. http://users.tpg.com.au/agnet/make%20piston%20rings.html |
Ramon Wilson | 18/04/2013 12:26:21 |
![]() 1655 forum posts 617 photos | Hi Windy, I confess I very rarely visit this site these days - totally frustrated by the spoiling of so many threads due to the adverts covering the posts. Fortunately this is not one of them. Just like to confirm that over the years I have successfully reclaimed several worn engines using this method which I first found described by my engine 'hero' George Aldrich in either Model Aircraft News or Strictly IC. It's possibly one of my posts you are reffering to. Just heating the cast iron to a nice bright red and letting it soak in the flame a bit before letting it cool slowly will increase the diameter slightly however quenching it - in oil - will give a bit more growth - about 1-2 thou on a 3/4" or so diameter. It can vary depending on the cast iron and as Neil says you can only do it the once. It's surprising sometimes just how much more material you have to play with. Lapping the bore before lapping and refitting the piston is better than just relapping the piston but I'm sure you'd be aware of that. Hope that helps a bit more Regards - Ramon |
Windy | 18/04/2013 12:41:11 |
![]() 910 forum posts 197 photos | Thank you for all the explanations it was Ramons posts that I was trying to remember. Memory at time needs a shake up. Paul |
