Here is a list of all the postings Francois Meunier has made in our forums. Click on a thread name to jump to the thread.
Thread: Bourdon Gauge |
16/02/2015 18:27:17 |
the original patent by Eugène Bourdon for its" tube" and application can be found on the INPI site, base brevets du 19ème siècle. this a manuscript, hardly readable : 33p of finely hand written text with a few figures, looking really odd. you can read only, no downloading, but you can order a copy. pretty deceptive! hope lhe link works , http://bases-brevets19e.inpi.fr/Thot/FrmLotDocFrame.asp |
Thread: Easy Aero Engine For First Timer |
06/01/2014 18:02:53 |
oscillators are usually proposed to the beginner, but I guess it is a poor way to learn engineering, oscillator even poorly fitted will run, simply increase pressure, fun to to watch but useless as regards learning machining skill. As suggested above, refurbishing an engine, making new piston to close tolerance and getting good compression is IMO far more instructive and not that difficult for a teenager already RC flight fan. |
Thread: Vertical boiler design |
04/12/2013 16:58:44 |
Hi for a large engine too, I was tempted to build a boiler similar to this one, riveted and soft soldered only, it looks nice and strong, or should I stop to chicken out and go for a brased job ? Cheers Zephyrin |
Thread: Stevenson valve gear. |
06/06/2013 08:52:21 |
Thread: Expanding worn pistons |
16/04/2013 21:27:01 |
upon heating to red and quenching in oil, your worn piston do hardly enter in the cylinder, amazing, it gives some meat to lap again, the increase in dia was about 0.02 mm for a 25 mm piston, but not not regular, more pronunced on the lower, thinner part, somewhat oval too..., may be not quenched properly. Zephyrin Edited By gedeon spilett on 16/04/2013 21:28:25 |
Thread: Annealled brass |
27/03/2013 10:13:12 |
For a steam boiler, copper and brass will undergo a rapid hardening upon pressure test and later use. Old bits of brased brass parts reharden spontanously in my scrap bin (much less "drill bit snatching" Zephyrin |
15/02/2013 22:17:41 |
nice gauge you have, with vacuum too, more akin to a scientific instrument than a boiler gauge. I have one, a boiler gauge, and I use it regularly, a faithful Instrument...not only a mantlepiece curiosity. Cheers
Thread: Toleranced and open dimensions on drawings |
25/01/2013 18:18:51 |
I can cope with imperfect drawings. Cheers Zephyrin |
Thread: Valve Springs |
17/01/2013 08:21:50 |
ETW, redesigned and republished 20 years later (24 NOVEMBER 1960 issue, p. 635) his Kiwi engine, with weaker valve springs !
I recently did a 10 cc engine (video in my album) and was surprised by the raise in performance with the progressive increase in stiffness of the springs, about 2,2 kg to open the valve now. https://picasaweb.google.com/113249908069844921550 Edited By gedeon spilett on 17/01/2013 08:22:48 |
Thread: Flat living and workshop dreaming |
16/11/2012 09:35:47 |
Hi It reminds me of a roll top desk that I recycled into a workshop: once opened, a unimat SL and many hand tools, and after removing the vertical column and the vise and closed (and locked!) the cover, impossible to guess what I was making inside. I have spent so many pleasant hours with it; I have made many oscillating engines and even a Stuart D10. Not louder than the vacuum cleaner necessary after a turning session to clean the rain of brass swarfs. The motor does not turn the whole day anyway, many machining and fitting sessions are silent and do not prevent listening to music or the radio. Must also avoid spraying and flooding with oil and coolant, a small brush is sufficient. Clearly, I am a lot more comfortable in my garage now, and I make much larger models, but I have spent with my desktop workshop some of the happiest moment of my life, I was also much much younger... I still have the Unimat, I will try to find a place for it inside, like in my youth, my garage is getting pretty chilly these days… cheers |
Thread: Non de plumes |
12/10/2012 19:51:17 |
I am very happy to show my engines and my models to other model engineers and other experts even if it is to be criticized, but I do not like to show what I do to people who know me and who know nothing in model engineering and generally laugh at it (poor morons). so there is nom de plume |
Thread: Drawings / Artcles |
26/07/2012 12:22:39 |
In his book "projects for the Unimat", Rex Tingey published drawings an building notes for a 1/16 scale traction engine "Sweet Sixteen", at large a reduced version of Minnie but the engine of his own valveless design. I did it many years ago, replacing the ugly cylinder by a plain reduced version of the minnie cylinder and valve gears, a awkward and minute job I remember..but very happy with the result. you can see a picture in my picasa album Cheers
Thread: USS Monitor |
29/04/2012 21:51:11 |
Hi nice engine, surely fascinating to watch running
You can find here an interesting discussion by J Ericsson himself on its Ironclad Monitor and also on the efficiency of its engine and some reasoning on its design. beautiful and dramatic engraving of the vessel and a few plate of the engine too. pages 479 & seq. & plates 48- 52). Zephyrin |
Thread: Lantern Chuck |
29/03/2012 07:38:40 |
Hi Saxalby Smart & elegant tool you made.
How do you change the protruding length of the screw/bolt ? is the pad on which the head of the screw rests movable ? applying side thrust for forming the end of a long and slender screw is not possible. I did a similar tool of the John Wilding design (in "Using the small lathe" Zephyrin |
Thread: How many T-Slots on a Rotary Table, 3,4,6? |
06/12/2011 22:35:48 |
Hi,
Thread: metric taps |
23/11/2011 23:19:21 |
Hi
Listen my friends, this fellow has just a hole to drill and tap M8. drill 6.75 to 7.1 according to hardness or drill bits available or tap quality( Carbon steel, HSS, new, worn, Chinese, British...) or type (hand tap, machine, gun, roll, three or four fluted..straight or helicoidal) the discussion is not over ! I agree with JasonB that commercial M8 screws & bolts are smaller than the ISO standard. nuts and bolts found in supermarkets & DIY stores give together a sloppy fit, IMO. Zephyrin |
Thread: Rigidity of X2 Mill |
20/11/2011 12:07:59 |
Hi,
look at the picture from the manual of my X2. it is the piece 39 that makes the column has some flexibility, not the column. it is a simple square in cast iron with a small base and 3 bolts almost in line. you cannot enlarge the base without reducing Y travel
Scraping and cleaning this base and the corresponding surface as you did is the best we can do this this machine, or buy a X3...
cheers |
Thread: gas canister threads |
08/07/2011 08:54:04 |
Hi,
the thread is 7/16" x 28 TPI UNEF, ( 11.11 mm x 0.907 mm
![]() this is for the camping-gaz disposable canister
I recently did an adapter by screwcutting the closest thead possible on my lathe (0.918 mm), which fits quite well, tolerances are not that tight.
taps are available at "Rotagrip" on the internet.
cheers
Zephyrin |
Thread: Converting CAD files to PDF |
01/06/2011 21:01:59 |
Hi, look in the list of printer available in your cad prgm, you should find CutePDF in the list, if properly installed in your computer. You don’t "save" but "print" a file in PDF format, i.e. in your computer. It is exactly why the pdf format was created, and btw the PDF format is in the public domain, and not the property of Adobe. |
Thread: French Model Engineer |
28/04/2011 21:02:20 |
hi,
3) weber métaux
(a large variety of metals, and centrifugically cast iron, a first class stuff)
www.weber-france.com 4) Sidermeca also, www.sidermeca.com/ sell metals “matières premières” cut from bar stock in the required amount however, I have no address for castings, it’s a pity Zephyrin |
