DavoJ | 07/04/2013 08:49:37 |
9 forum posts | Sorry will try again
Edited By DavoJ on 07/04/2013 08:51:17 |
Stub Mandrel | 07/04/2013 09:24:35 |
![]() 4318 forum posts 291 photos 1 articles | Hi Davo, Are you having a problem with pictures? Neil |
JasonB | 07/04/2013 10:17:34 |
![]() 25215 forum posts 3105 photos 1 articles | If its the same post you have made on other forums then copy & pasting the whole thing won't work on here. You can't use teh IMG codes so will have to load each image url using the image icon along the top of the reply window
J |
John Stevenson | 07/04/2013 10:24:30 |
![]() 5068 forum posts 3 photos | Why not just link to a previous post on another forum ?
Like this.
NJH | 07/04/2013 11:05:46 |
![]() 2314 forum posts 139 photos | Hi Davo That is certainly impressive! 46 holders though - I have 16 and sometimes have difficulty finding the right one - with 46 you may be in danger of Quick Change, Slow Find! John - thanks for giving us the facility to view Davo's project I don't think this site could cope with that volume of images in any way that would provide a readily followed sequence. Cheers Norman Edited By NJH on 07/04/2013 11:06:16 |
DavoJ | 07/04/2013 13:25:11 |
9 forum posts | That would be easier to do, thanks for the tip. It was a lot of work, but so was posting it all with text. All up 52 photos and that took hours to upload. Dave
Edit, oops I should read a little better as you already provided a link. My link is to another forum. Thanks again Edited By DavoJ on 07/04/2013 13:27:02 |
DavoJ | 07/04/2013 13:29:52 |
9 forum posts |
Posted by NJH on 07/04/2013 11:05:46:
I am building a new cabinet that will have draws underneath for these. With the 6 I already have thats 52 I need to store with enough room for the tooling in them. I am going to make the draws with bearing and will post it up when I am making it.
joegib | 08/04/2013 14:29:27 |
154 forum posts 18 photos |
Hi Dave, Edited By joegib on 08/04/2013 14:31:03 |
joegib | 09/04/2013 12:39:38 |
154 forum posts 18 photos | In my previous post I asked Dave how he ensured that the distance between the Vees on the toolholders was exactly right. I see he's since dealt with exactly the same question over on the HSM forum so to save him the trouble of posting here I'm quoting his answer below: -------------------------------------------------------------------------------------------------------------------------------
I used the DRO wich has 0.005mm glass scales, the V's are exactly 60mm apart on this one so I was working to a round number at least. --------------------------------------------------------------------------------------------------------------------------------- Hope you don't mind me doing this Dave. Joe |
DavoJ | 10/04/2013 13:59:07 |
9 forum posts | Thanks Joe, I just found this post and I don't mind at all. I am glad it has inspired you to make a few special ones yourself and it's good to see that as it was a lot of work putting it that post together with 52 pictures and adding text for them. I think they are easier to make than the dovetail ones, though a lot of people think otherwise.With these it's just basic tooling other than the key seat cutter but it's a lot more durable than a dovetail cutter with it's delicate tips.
Dave |
John McNamara | 10/04/2013 15:06:30 |
![]() 1377 forum posts 133 photos | Hi Davo Have I sprung another OZ? The Lock tool knurl in one of your photos..... They used to be down the road in Lygon St Brunswick A suburb of Melbourne It was great to watch them forge the tools. Cheers John (Melbourne)
Clive Foster | 11/04/2013 18:47:22 |
3630 forum posts 128 photos |
Although the basic shapes involved in creating Dickson style tool carriers are quite simple the accuracy requirements are stringent and tolerances small. Due to the overhung nature of the cutting loads you need at least simultaneous line contact on all four sides of the Vee faces over pretty much all of the Vee length. The ideal is full area contact on all faces but that level of precision is for the likes of Moore Tool & Jig and similar companies. Even they struggle. Incomplete contact considerably reduces holder stability making it likely to tip under heavy cutting loads or parting tool type jam ups. Even factory products can suffer. I've demonstrated this a time or two with the T2 size set on my Smart & Brown 1024 when the HSS blade type parting tool jammed up. Surprisingly the tool didn't break although the first time an unnoticed crack in the blade carrier opened up and a 3/8 inch (ish) section of the lower blade holding ledge broke away. Clearly the carrier had suffered similar mishaps in a previous users care. Repair was "interesting" but the cost of a new blade carrier provided plenty of incentive. The wide spacing and large areas of the registration Vees make the Dickson style the most rigid and stable of QC system designs but performance in practice can be a little disappointing. They work well enough, especially if kept properly clean, but the results never seem to be as good as they ought. Inexpensive (and expensive!) no name clones have a fairly well documented reputation for instability due to excessive tolerance spread. One day I shall blue up my tool posts (3) and carriers (17) to see exactly what the factory Dickson and Rapid brand fits are like. On current schedules this will probably be somewhere north of 2025! Interestingly the double Vee lathe bed, as used by SouthBend, is much more relaxed over tolerances. Theoretically as few as 3 points of contact is sufficient for adequate saddle guidance although 5, suitably spaced, ones is a more practical minimum. Especially on small Southbend machines which lack an anti rise gib under the front of the saddle. Not having to deal with overhung loads makes a big difference. Its always surprised me that more makes didn't do things the SouthBend way especially as a bit of running in wear soon bumps up the contact area. Clive Edited By Clive Foster on 11/04/2013 18:48:35 |
