What thread? Stuart V-10
Svarven31/03/2013 10:42:20
35 forum posts
8 photos
What thread should you choose for the steam in and out connection to Stuart V-10, to fit common accesories.
And what thread for the drain taps?
Growing up with millimeter so I need advice.
Bertil
Stub Mandrel31/03/2013 12:04:18
4318 forum posts
291 photos
Hi Bertil,
You have my sympathies
40tpi is common for steam fittings. I used 0Ba and made my own unions as all I had were a few BA taps when I started out.
Lambton31/03/2013 18:24:09
694 forum posts
Dear Bertil,
I have made several Stuart No 10 and other engines and I have just looked at the drawings used.
Steam fittings in and out should for 10 H&V should be be ¼” x 32 tpi
Drain cocks (smallest of the 3 sizes available) 5/32” x 40 tpi (from the Stuart models catalogue).
I hope this is of help.
Eric
Jens Eirik Skogstad31/03/2013 20:37:55
400 forum posts
22 photos
In case you has not imperial treads for drain cocks, use M4 treads in the cylinder and make own drain cock, it is not difficult. I did with my Stuart D10 with ownmade drain cocks since the draincocks is not cheap to order from UK due toll tax.
Edited By Jens Eirik Skogstad on 31/03/2013 20:38:40
Steve Withnell01/04/2013 12:14:22
858 forum posts
215 photos
I think if you thread as specified on the Stuart drawing, I think you are then committed to the Stuart fittings, be worth double checking, measure twice, cut once...
Svarven02/04/2013 16:51:00
35 forum posts
8 photos
Thanks
Jens Eirik do you have any drawings for yor draincocks?
Bertil
Jens Eirik Skogstad02/04/2013 20:08:24
400 forum posts
22 photos
Svarven, i do not have the drawnings of the draincocks. I can make a drawings to you if you want.
Svarven03/04/2013 19:07:38
35 forum posts
8 photos
Tank you Jens.
If you would do that work i should be happy.
Bertil
Jens Eirik Skogstad03/04/2013 20:31:45
400 forum posts
22 photos
Hi, here is the drawings of the drain cocks in millimetre for "non imperial" engineer **LINK**
Svarven04/04/2013 19:43:45
35 forum posts
8 photos
Thanks
Looks good.
Bertil
