Here is a list of all the postings Svarven has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart D10 Metric Plans |
29/07/2014 14:44:01 |
Stuart have a building guide book, with metric dimensions for no 10.
TEE Publishing ISBN 1 85761 096 2 revised 1995 |
Thread: Drill press KTF-13 |
04/01/2014 16:10:08 |
Thanks Now i have to test that.
Bertil |
01/01/2014 17:38:56 |
I have to disassemble the spindle then this unfortunately was a little crooked. So it can be when buying used items. |
Thread: What did you do today? (2014) |
01/01/2014 17:02:13 |
Offensive word removed by JasonB Edited By JasonB on 01/01/2014 17:18:14 |
29/12/2013 13:34:45 |
Hi Is there anybody who have a manual or drawing for the KTF-13 Drill press (King Feng Fu Machinery works co Ltd)
Bertil |
Thread: workshop floor - ? epoxy |
23/04/2013 21:10:14 |
Oxan floor oil is the outstanding for concrete floor. We hav used that since 1980 for our machine shot at school. Easy to repar and strog. Stands for welding too. |
Thread: What thread? Stuart V-10 |
04/04/2013 19:43:45 |
Thanks Looks good. Bertil |
03/04/2013 19:07:38 |
Tank you Jens. If you would do that work i should be happy.
Bertil |
02/04/2013 16:51:00 |
Thanks Jens Eirik do you have any drawings for yor draincocks?
Bertil |
31/03/2013 10:42:20 |
What thread should you choose for the steam in and out connection to Stuart V-10, to fit common accesories.
Bertil |
Thread: Planet CNCUSB software |
03/03/2013 12:07:04 |
Yes you have many intelligent questions and lots of experience. |
03/03/2013 08:17:11 |
OK John Dont you think that pocket fult is solved now, thereis a lot of updates made. A thing i liked very mych is the automatic toll hight calibration in the home point. (http://www.youtube.com/watch?v=ToeWsqf7Dhs) I hav not find that in Mach3. I have not used Mach3 so much, but I and my students have converted a smal mill to cnc as a project. There we used mach3 and tha thougt it was difficult to set up. But it can be that we dont have read the big manual carely enough.
I want a software which is simple to use, cheep, but can do all things you need for a mill, lathe and a router. Im not interested in making anny programing into the software, so for me it isent a need for open source. But it must be safe, no broken tools. Bertil |
Thread: Cutter and lathe tool grinder advice need |
02/03/2013 21:23:52 |
Hi I think i start with Harolds rest first, as it is easy to make and cheep too. Then i vill make an havier one. Witch one, im not sure. Would be interesting to se the drawings of the BSMME grinder. Im glad to be here at this forum, you are all so helpful. excuse for my bad english. But im much better at swedish
Bertil |
02/03/2013 20:51:32 |
Hi Is there anybody who use this program. If so, im interested if its good or not. www.planet-cnc.com
Bertil
Thread: Schedule of the TB6560-V2 stepper control card |
27/02/2013 20:27:46 |
Yes John i have , but have not get any answer from the seller.
Bertil |
27/02/2013 20:24:25 |
Thak you Les. What programmer dis you use to program the PIC. Bertil |
27/02/2013 18:23:13 |
Thanks
Les J, i looked at you album and found an interesting tacho, do you have the drowing and what kind of sensor are you using to it.
Bertil |
27/02/2013 18:07:18 |
John S have you looked at you cd?
Bertil |
27/02/2013 18:03:39 |
Hi Harold I think about the one in the book "Milling a complete course".
Im not a member of the bristol modellenginners so I could not open the drawing page. So howe to by the Colyer/Caseley cutter grinder drawing then.
Bertil |
26/02/2013 19:49:04 |
Thanks Harold
I have looked at your sanding block many many times in the grinding book. but thought it looked a bit too weak out.
Bertil |
