Euro quick, BSP and NPT fittings
John Coates | 19/03/2013 06:57:53 |
![]() 558 forum posts 28 photos | Just bought the 2.5hp compressor from Aldi last week as my current one is much smaller Anyway the two airline connectors are "Euro quick" - which seem to be the same as 1/4" BSP as on my small one but I just thought I would check on here as connectors of this size don't seem to fit tightly when test fitting my air tools. I need to order two airlines and want to make sure I order the correct ones. Also I bought a Snap On die grinder from a fellow motorcycle forum member but it doesn't have a connector on it. The female thread is 1/4" NPT which is 19 tpi and the same size BSP is 18 tpi and I have read not to mix the two. Where can I buy a connector which has the right female thread for the grinder but a "normal" BSP or Euro quick connector at the other end? What I thought I needed to buy were two airlines with Euro quick connectors at the compressor end and 1/4" BSP at the other end for my air tools but I'll hold fire until you chaps can better inform me Thanks for any help. I hope this doesn't incite any "what the hell is this question doing on a model engineering forum?" responses as I have tried to express it clearly in the title and description and choice of topic area
John |
mick H | 19/03/2013 07:30:19 |
795 forum posts 34 photos | Machine Mart hold quite a range of compressor tool fittings. It might be worthwhile giving your local branch a ring. Mick |
magpie | 19/03/2013 07:50:39 |
![]() 508 forum posts 98 photos | I bought a 2hp compressor from Aldi many years ago and the only bit that has failed is the regulator. I bought a new one from Machine Mart and that is still ok. The first thing i did when i bought the compressor was change ALL the fittings to PCL connectors. If you have no luck with Machine Mart try Snap-On, I understand they do a fair bit of British and Euro stuff these days. Cheers Derek. |
RJW | 19/03/2013 08:39:05 |
343 forum posts 36 photos | I changed all of mine to PCL type quick release fittings, they're cheap enough on eBay, typically eBay item numbers 120929207852 or 110859540774 Cheers, John. Edited By RJW on 19/03/2013 08:40:37 |
Windy | 19/03/2013 08:40:19 |
![]() 910 forum posts 197 photos | I converted my Aldi compressor to PCL connections if you have a motor factors near you many supply PCL fittings, This firm on page 45 sells them and deliver PCL fittings fast. Paul |
John Stevenson | 19/03/2013 09:17:18 |
![]() 5068 forum posts 3 photos | Posted by John Coates on 19/03/2013 06:57:53:.
Since when has 1/4" BSP been 18 tpi ? |
John Coates | 19/03/2013 13:02:56 |
Posted by John Stevenson on 19/03/2013 09:17:18:
Since when has 1/4" BSP been 18 tpi ? Hi John Didn't have my Zeus to hand to check when I wrote this. This was off an American website comparing the two threads. I'll check when I get home t'other John |
John Stevenson | 19/03/2013 14:24:54 |
Ignore the yanks they can't get anything right. |
Keith Long | 19/03/2013 16:14:38 |
883 forum posts 11 photos | John Worth looking in the Cromwell tools catalogue (on line) as well. They do a whole load of pneumatic fittings. I think they also do npt-bsp adaptors as well for the sizes that need it. Keith |
john fletcher 1 | 23/03/2013 09:54:33 |
893 forum posts | Getting back to the top item above and out of interest, why should one change from euro quick fittings to PCL which I am familiar with. Are Euro quick less durable or easily damaged, they seem readily available on ebay. I have bought an Aldi compressor and then saw this item. Your comment will be much appreciated.Ted |
John Stevenson | 23/03/2013 10:10:35 |
![]() 5068 forum posts 3 photos | Ted, It's probably what you already have to make everything compatable. Up until last year I was on Shraeder fittings for the simple reason when I built the workshop and started putting in steel air lines my local scrap yard had bags of Shraeder fittings from Plessey's old factory which they demolished.
However fast forward 20 odd years and most of these were leaking and new fittings are expensive, it payed me to change over to PCL's in one go purely on cost.
Female Shraeders were £5 to £7 each, PCL's were just over a pound, male Shraeders were about £2.50 and if you bought bulk PCL's about £0.70 |
