Philip Leith | 17/03/2013 21:08:43 |
15 forum posts | Looking for tufnol supplier - 25mm by 4 or 5mm by 2000mm (for the hatch runners on a sailing boat). Any ideas where this might be got from? I can see sheets and rods online, but not much in the way of strip. |
David Clark 1 | 17/03/2013 21:14:00 |
![]() 3357 forum posts 112 photos 10 articles | Hi There 40 years in industry / engineering and I have never seen strip. We always cut it out of sheet or bar. regards david |
Philip Leith | 17/03/2013 21:19:07 |
15 forum posts | David That must mean there is someone out there who would cut me a couple of strips, perhaps? Who uses tufnol? If I knew that I could hunt it down. Philip |
Andyf | 17/03/2013 21:27:02 |
392 forum posts | I was looking for a bit of Tufnol this morning. Here's a piece on Ebay which you could cut into strips. Only 2.5mm thick, though I suppose you could double it up. Andy |
Philip Leith | 17/03/2013 21:31:39 |
15 forum posts | Yes, saw that. It is a possibility but would prefer something more robust if I can get it. |
JasonB | 17/03/2013 21:31:45 |
![]() 25215 forum posts 3105 photos 1 articles | These people also do a cut to size service Edited By JasonB on 17/03/2013 21:32:06 |
Philip Leith | 17/03/2013 21:40:56 |
15 forum posts | Thanks - will contact them and see. |
M0BND | 17/03/2013 21:49:51 |
81 forum posts 9 photos | Sorry, I know this may be a bit late but .... http://www.tufnol.com/tufnol/default.asp Andy. |
Steambuff | 17/03/2013 22:58:37 |
![]() 544 forum posts 8 photos | M-Machine do Tufnol (Cut from Sheet) in 5mm thick. They will usually cut to the size you require.
Dave |
John Stevenson | 17/03/2013 23:20:25 |
![]() 5068 forum posts 3 photos | I use a lot of tufnol strip as insulators and brush ring gear on electric motors.
The link Jason gave is the company I use and I have found them to be the most cost effective company and believe me when you are paying the bills you do look
I keep every thickness in stock up to 12mm but unfortunately I only order in 600mm or 1M lengths max as i never have to do long peices and it's easier to store in 1M lengths than 2M |
Philip Leith | 18/03/2013 08:50:53 |
15 forum posts | I will measure up properly today. I think I can use two pieces end to end. Thanks for all the advice - very helpful indeed. |
