Making a piano hinge bind and get stiffer
Graham Wharton03/03/2013 14:54:22
149 forum posts
48 photos
Hi there,
Does anyone have any ideas on how to make a piano hinge stiffer to operate. I have some polycarbonate sheets acting as chip guards on my mill which are hinged like doors on uprights using piano hinges. They swing wildly with the slightest breeze and vibration. I'd like to get it so I move the door into position and it stays reasonably where it is.
Ive tried pinching the hinge with pliers in two places but that seems to have had little effect.
Any genius ideas for me to try.
Thanks
Graham
Les Jones 103/03/2013 15:13:34
2292 forum posts
159 photos
Hi Graham,
Without removing the pivot pin from the hinges squeezing them will not distort the tube part of the hinges. If you can knock the pin out squeezing the tube part in a vice would give more control than pliers. Remember to squeeze at least one segment of EACH side of the hinge. A way that might work without removing the pin would be to very slightly bend one or more segments of each side of the hinge. Clamp the hinge in the vice with half the length of a segment sticking out and tap it with a hammer to produce a very slight bend in it. If you have any bits of the hinge left over try the above on them first.
Les.
Edited By Les Jones 1 on 03/03/2013 15:16:17
Andyf03/03/2013 15:20:12
392 forum posts
I assume they look like double doors, though maybe not meeting in the middle. Could you fit a peg to the top of each door at the far end from the hinge, open the doors to the required angle, and then slip a Meccano-type strip over the pegs so as to connect the doors together?
Then, viewed from the top, you would have a rigid-ish trapezium, though if the door opening approached 90° it would get more like a rectangle, liable to collapse into a parallelogram in the breeze. To prevent that, put extra pegs at the hinge ends of the door tops, and use two Meccano strips in an X shape (but not fastened together) . Then you would have two triangles, which would be more rigid and permit one door to be open more than the other.
Andy
Keith Long03/03/2013 16:03:18
883 forum posts
11 photos
Slipping some packing between the hinge plate and the support upright to induce a local distortion in the hinge pin might work - my usual problem is the opposite - getting doors to swing freely!
Keith
jason udall03/03/2013 16:49:37
2032 forum posts
41 photos
Try moving "middle" fastners out of line...bow the hinge pin sort off...like the above maybe packing to the same effect.
...drill and tap for grub screw...replacing part of hinge pin...allows for "adjustable" friction..
Brian O'Connor03/03/2013 16:59:54
74 forum posts
19 photos
Try using Loctite, not the very strong stuff but the type that you put on nuts and bolts that allows you to undo them at a later date. In my last house there were several doors that opened or closed themselves due to the frames being out of true. An application of Loctite taught them some manners and lasted for several months before further applications were required.
Chris Trice03/03/2013 17:12:52
1376 forum posts
10 photos
Take the pin out and replace it with a similar size length of piano wire but introduce a gentle zig zag shape every half inch or so into the wire with a pair of pliers.
Graham Wharton03/03/2013 17:27:29
149 forum posts
48 photos
Ive given the loctite suggestion a go first as that involves pretty much no effort. If that doesnt do the trick, then I'll look into packing out the middle screws on the hinges to create distortion, then last resort, remove the pin from the hinge and do some selective pinching.
Les..... "Remember to squeeze at least one segment of EACH side of the hinge." <- on inspection of my attempt number one, i had indeed fallen at the first hurdle!!! blush
Cheers guys.
Graham
Billy Mills03/03/2013 18:30:35
377 forum posts
Be very careful with loctite near acrylic or other plastics, some kinds can cause the plastic to break up after a few months. Learnt the lesson the hard way some years ago, we had to replace hundreds of switch assemblies that had been given a drop of locking compound " to stop them coming apart" !
Billy
Mark P.03/03/2013 18:42:47
634 forum posts
9 photos
Hit it wiv an ammer!
Mark P.
D.A.Godley03/03/2013 19:00:05
143 forum posts
41 photos
Posted by Mark P. on 03/03/2013 18:42:47:
Mark P.
Don't you mean a Brumigam spanner ???
Falco03/03/2013 21:28:48
65 forum posts
7 photos
Work a little polyeurethane varnish into the hinge and let dry. Make sure it gets in around the pin.
Gordon W04/03/2013 09:46:22
2011 forum posts
Similar to Falco above, but I've used kitchen sealer or similar, polyurathane type not acrylic. Also good for locking threads etc.
