New Vice
Boiler Bri01/03/2013 18:03:32
856 forum posts
212 photos
I need to replace my 'chinease made' vice with a new one, has anyone bought one of these? If you have are they any good?
Vice on Ebay
Bri
Edited By David Clark 1 on 01/03/2013 18:19:58
David Clark 101/03/2013 18:19:10
3357 forum posts
112 photos
10 articles
Hi Brian
I would want to know what the inside of the vice between the jaws is.
Some of these cheap vices have a rough casting between the jaws or a bit of a rough gap so you can't put a parallel in it.
Also, the base loses you headroom but if you remove it, you can only use the vice at 90 degrees to the X axis.
That would be fine for most of the time but 10% of the time you may need the vice in line with the X axis and unless your Tee slots are the right distance apart you may not be able to clamp it down.
regards David
John C01/03/2013 18:37:39
273 forum posts
95 photos
Bri, whereabouts are you? RDG are advertised as being at the Manchester Modelling Exhibition in the Trafford Centre tomorrow - you could go and have a look.
magpie01/03/2013 22:52:32
508 forum posts
98 photos
If the RDG stand at the Manchester show is the same as last year, it will not be very big and only have a small amount of there stuff on it.
Cheers Derek.
Chris Trice02/03/2013 02:04:32
1376 forum posts
10 photos
I've got one of the vices in the link and it's very good (although prone to rusting), however I don't use it on my milling machine as I prefer a similar one but without the swivelling base.
Boiler Bri02/03/2013 06:55:25
856 forum posts
212 photos
Thanks for the ad-vice. I am ok with height as i have a warco that the head can go up and down. It was the quality side of things that worried me. On the one that i have the moving part lifts a little when i clamp things in it. If i forget to tap the part level i end up with a taper cut.
No chance of Manchester, her who must be obeyed needs to visit a shop in colne tomorrow and the nearest i will get to anything like moddeling will be Howarth railway.
Cheers
Bri
magpie02/03/2013 07:32:41
508 forum posts
98 photos
Brian, the show is open on Sunday as well.
Cheers Derek.
