David Brown 5 | 17/02/2013 21:32:29 |
8 forum posts | Hi my first post, just got my super 7 lathe and i have ordered a quick change tool post from Myford. The lathe came with a 4 way tool post and I cant use my 10mm indexable tools they sit to high, Question what is the largest indexable tool you can fit in this holder? |
David Clark 1 | 18/02/2013 08:30:58 |
![]() 3357 forum posts 112 photos 10 articles | Hi There I bought a cheap 4 way tool post and faced the bottom off until 10mm tools fitted it. regards David |
Jo | 18/02/2013 08:43:24 |
198 forum posts |
Jo |
Jo | 18/02/2013 09:18:05 |
198 forum posts |
David (B), are you talking about the four way tool post or your new QCTP? If the latter then you will have no problem with your 10mm tools, there will be enough adjustment.
If you look to reuse your four way tool holder as a rear tool post with a suitable packer you will have no problem with tool height as the cutting edge is at the bottom rather than the top. Jo |
JasonB | 18/02/2013 09:21:54 |
![]() 25215 forum posts 3105 photos 1 articles | You could also look at the imported holders that fit these tool posts as some have a thinner bottom "lip" which will allow you to get the tool lower and save the ones that came with the post for smaller tooling. Watch if you try to machine off the bottom of the holder and they are usually hardened to some degree depending on who made them. J |
Roger Vane | 18/02/2013 09:44:00 |
108 forum posts 18 photos | Hi All Beware though, I've bought some imported toolholders where the bottom 'lip' was quite thick meaning that my 10mm tools wouldn't fit. I've now got a good number of these and there is quite a lot of variation - I've just measured some and the bottom lip varies in thickness between 5.6mm and 6.9mm. Roger
Roderick Jenkins | 18/02/2013 10:15:55 |
![]() 2376 forum posts 800 photos | How high the tool tip is also depends on how low the tip fits in its toolbar. On some of the cheaper tools the tip sits proud of the upper surface. Rod |
Kevin Bennett | 18/02/2013 16:44:08 |
![]() 193 forum posts 56 photos | hi i had to machine 1.2 mm off the bottom to get the tip tool to canter Kevin |
David Brown 5 | 18/02/2013 16:44:09 |
8 forum posts | Thanks for the replies i will let you know tomorrow if my tooling fits, will look into modifieing the 4way. |
David Brown 5 | 20/02/2013 22:28:31 |
8 forum posts |
Well I am happy to say my 10mm indexable bit fits fine and it all works a treat |
