passenger car wheels
Joseph Ramon09/01/2013 14:32:29
107 forum posts
Is it feasible to make passenger car tyres from thick tube and alloy wheels within?
Joey
fizzy10/01/2013 16:20:51
1860 forum posts
121 photos
Is this a joke?
Andyf10/01/2013 16:26:22
392 forum posts
I think Ramon may mean railway passenger cars, or coaches, using alloy wheels fitted with tyres machined from slices of thick steel tube.
Andy
Stub Mandrel10/01/2013 21:16:27
4318 forum posts
291 photos
If you mean fitting steel tyres to alloy wheels, I don't see why not. Is there a particular reason for going down this route (I ask as I have a half-started driving car may have some tube I could use for tyres, but I'm not sure if I do what I could use for wheels).
Jeff Dayman10/01/2013 22:14:53
2356 forum posts
47 photos
Don't forget to consider the different thermal expansion coefficients for aluminum vs steel or iron. On a cold day, the alum will contract more than the steel, and on a hot day it will expand more than the steel. If this is planned for in the fastenings and fits, it should not be a problem, but do your math before building.....or make the whole wheel from steel and worry no longer.
Keep in mind too the rough rule that aluminum is 1/3 the weight of mild steel but is also 1/3 the strength of mild steel.
JD
magpie10/01/2013 23:08:26
508 forum posts
98 photos
Fizzy, i think Joey is perhaps thinking of cutting a short length of a large diameter thick wall tube, rather than wrapping a piece of tube round a hub !!!!!
Cheers Derek
fizzy11/01/2013 00:04:23
1860 forum posts
121 photos
very spurious!!
I still dont like spiders!!
Bazyle11/01/2013 01:12:40
6956 forum posts
229 photos
You would also need a different material for the centre bearing.
Potentially with reasonable use the outer rim will get stretched by effectively being continually cold rolled and become loose unless a hard steel is used and shrunk on. Perhaps you were thinking of cast alloy spokes. If just to avoid expensive castings or gettting large steel discs cut perhaps welded plate centres would do.
Joseph Ramon11/01/2013 11:31:26
107 forum posts
Sorry for causing confusion. I have the material to hand to make steel tyred wheels with aluminium hubs on steel axles. The warings about it coming loose sound feasible, so I will rethink.
Thanks
Joey
Edited By Joseph Ramon on 11/01/2013 11:32:45
Andrew Johnston11/01/2013 12:35:22
7061 forum posts
719 photos
Posted by Jeff Dayman on 10/01/2013 22:14:53:
It's roughly right, but not the whole story.
The density of iron is about 7850kg/m^3, aluminium is about 2710kg/m^3, so as correctly stated aluminium is about a third as dense as steel.
A typical tensile strength for EN1A is 400MPa, for pure aluminium (1050) about 130MPa, depending upon temper. So pure aluminium is only a third of the strength of EN1A. However, pure aluminium (1050) is unlikely to be available in any form other than sheet, as it bends easily without cracking, but machines badly.
The inners of the wheels would most likely be made from an aluminium alloy. For a common aluminium alloy, 6082, with a mid-temper, tensile strength is around 260MPa, so more like two thirds the strength of steel. For an aircraft spec aluminium alloy, 7075 with a T6 temper, tensile strength is around 500MPa, so stronger than steel. If it wasn't then we'd make aeroplanes from steel as it would be cheaper. smiley
Stub Mandrel12/01/2013 15:51:06
4318 forum posts
291 photos
This has got me wondering if I still have the body shell from an old mini-lathe motor? It might provide tyres/rims to suit my driving car if my welding is up to adding steel centres.
