ron grimshaw | 30/12/2012 14:58:19 |
![]() 40 forum posts |
I would like to fit a speed control to Warco Turrit miii, It has a single phase motor fitted, if this can be done, using what and best to buy and how easy |
John Rudd | 30/12/2012 15:20:09 |
1479 forum posts 1 photos | I recently completed a 3-phase conversion to my Chester Eagle 30 mill.
I bought a drop in motor rated at 1.1kw ( basically the same rating as the single phase motor) from an Ebay seller for around the £110 mark and a suitable vfd from another seller for less than £80... Add together the cost of some wiring and switches the whole conversion was done for less than £225...
Without knowing what motor size you have on your mill, I cant advise...
Cheers
John |
Les Jones 1 | 30/12/2012 15:20:10 |
2292 forum posts 159 photos |
Hi Ron, Les. |
Kevin Bennett | 30/12/2012 16:07:10 |
![]() 193 forum posts 56 photos | hi i use a 12v car window motor and a small clutch with a variable 2 way speed controller works fine on my Chester mill and it is a safe voltage ty Kevin |
Terryd | 30/12/2012 16:14:14 |
![]() 1946 forum posts 179 photos |
Posted by Les Jones 1 on 30/12/2012 15:20:10:
Hi Ron, Les. Hi Les, My Milling machine (equivalent to Warco WM18) and Warco lathe WM280V-F have single phase motors and variable speed. How is this achieved if what you say is correct. I know little about motor control, Best regards for the New Year, Terry |
KWIL | 30/12/2012 16:16:54 |
3681 forum posts 70 photos | Kevin Surely you mean this for the table traverse? Ron needs it for the spindle drive. |
Kevin Bennett | 30/12/2012 16:33:13 |
![]() 193 forum posts 56 photos | KWIL yes miss read it as i had a bad day???????? |
John Rudd | 30/12/2012 16:34:06 |
1479 forum posts 1 photos | To the best of my knowledge, the WM18 mill and the WM280V lathe both have DC permanent magnet motors which easily lend themselves to speed control using either MOSFET based or SCR based controllers. |
Les Jones 1 | 30/12/2012 16:37:39 |
Hi Terry, Les. |
Terryd | 30/12/2012 16:56:50 |
![]() 1946 forum posts 179 photos | Hi Les, Have just checked the lathe spec and apparently it uses a DC motor which probably explains it, Regards, Terry |
