setting up a vertical head
tony bastick11/12/2012 21:58:46
15 forum posts
I have a Senior M1 milling mc with a std vertical head and when set up to the markinge scribed on the mc it does not cut square to the table but is about 1/2 a degree out of plum. Does anyone know of a quick way to set up a vertical head accuratly?
Phil P11/12/2012 22:01:09
851 forum posts
206 photos
You could do a lot worse than get one of these.
http://www.machine-dro.co.uk/edge-technology-pro-tram-system.html
Look up "tramming" to tell you a few other methods.
Phil
Nobby11/12/2012 22:46:44
587 forum posts
113 photos
Hi Tony
Put an accurate square on the quill  from the Machine bed for a start Slapped wrist. !!!!
Nobby
Edited By Nobby on 11/12/2012 22:48:40
Harold Hall 111/12/2012 23:15:26
418 forum posts
4 photos
Even with suitable test equipment Tony, making the very minute adjustments necessary can be very tedious. The method shown in photograph 5 here enables very small adjustments to be made easily. In simple terms, the table's traverse is used to push, or pull, the head sideways by very small amounts and with the dial indicator showing the results as it is being done . The text explains it in detail.
Harold
Harold Hall 111/12/2012 23:23:12
418 forum posts
4 photos
I should have added that the machine standards state that the departure from perpendicular should be no more than 0.025mm over 300mm amounting to a maximum angle of 0.005°. Hence my comments about minute adjustments. Again this is explained in the text.
Harold
Phil P12/12/2012 13:15:44
851 forum posts
206 photos
This the set up I currently use on my Alexander Mill
Phil
Edited By Phil P on 12/12/2012 13:18:24
Stub Mandrel12/12/2012 17:39:09
4318 forum posts
291 photos
HI Phil,
I like that My 'sheet of plate glass' approach is very vulnerable to wee bits of swarf on the mill table.
tony bastick12/12/2012 22:22:39
15 forum posts
Thanks all for your helpfull tips, but Nobby the Senior Mill has no quill or machined surface on the head.Thony
Nobby12/12/2012 22:32:53
587 forum posts
113 photos
Hi Tony
Another slapped wriist . When I clocked (Tramming) the Bridgeport etc using a similar set up as Phil but used a slip to run the dti over.
I did notice the Nut & split on the head can it be wound down ?
Happy Tramming & Xmas
Nobby
Phil P12/12/2012 23:34:00
851 forum posts
206 photos
The reason my tramming device is stood on three legs, is so it can sit on the mill table spanning the vice. The three legs are simply adjusted to the same length using a micrometer, that ensures the surface is truly parallel to the table.
I cannot claim any design rights on this tool, I saw this and realised I could make one in about half an hour.
http://www.eztram.com/what.asp
Nobby
The vertical head does have just over two inches of quill movement.
It is an Alexander Master Toolmaker, the UK equivalent of a Deckel FP1
http://www.lathes.co.uk/alexander/index.html
Phil
