Dougie Swan | 25/11/2012 11:46:49 |
269 forum posts 73 photos | Can anyone help with information on a supplier of ignition coils, either 6 or 12v Thanks Dougie |
JasonB | 25/11/2012 13:24:03 |
![]() 25215 forum posts 3105 photos 1 articles | Minimag will do a small coil and also a box of tricks so you can trip it with a Hall Effect sensor. If you do go with the Galloway then the ignitor needs a low tension coil which can be obtained from an old strip light fitting. The CDI units from S&S also get good reports, again these are Hall effect triggered You can also build one with a small motorbike coil sourced from e-bay, these can also be made to make a buzz coil ignition if that is what the engine calls for.
J |
mick | 25/11/2012 13:30:37 |
421 forum posts 49 photos | Try your local motor cycle repair workshop. I got a small set of points and a coil with condenser attached for £25. |
Grizzly bear | 25/11/2012 17:38:48 |
337 forum posts 8 photos | Hi Dougie, I purchased two off ebay, different sellers. The H.T. coils were 12v & used, but OK. Regards Bear.. |
Ian S C | 26/11/2012 10:42:07 |
![]() 7468 forum posts 230 photos | Dougie, I believe there is a system used these days (I'v not come across it), that uses individual coils for each spark plugs, there is a bit about them on some other web site. Ian S C |
Andrew Johnston | 26/11/2012 10:55:57 |
![]() 7061 forum posts 719 photos | High performance cars, especially racing cars, have been using on plug coils for some years. It saves the complication of a high-voltage distributor and is better for EMC. Andrew |
JasonB | 26/11/2012 12:02:44 |
The on plug coils do look totally out of place on a old hit and miss type engine, almost as bad as having a full size car coil on display
J |
Ian S C | 27/11/2012 10:26:11 |
![]() 7468 forum posts 230 photos | The on plug coil, would not need to be on the plug, it could be hiden, say in a dummy magneto. Ian S C |
