Tapping into boiler
fizzy06/11/2012 12:20:09
1860 forum posts
121 photos
Ive just drilled my 7ba pilot hole too deep and gone straight through the boiler wall. Ibe tapped 7ba and coated the bolt threads with bearing lock (weak loctite), should this be enough to stop it leaking?
Jeff Dayman06/11/2012 12:37:06
2356 forum posts
47 photos
At room temperature, probably, but at steam temperature, not likely. If it were me, I'd drill it out (and all others like it) and fit bronze bushes silver soldered in place.
Many designers of model engines specified tapped holes into the boiler shell for attaching things, Martin Evans in particular, even if only two full threads would be possible. Just not good practice. A boss through, or a tapped lug soldered on the outside of the shell under cleading is a much safer method.
JD
KWIL06/11/2012 14:02:28
3681 forum posts
70 photos
Steel boiler Fizzy? Weld the hole with MIG?
fizzy06/11/2012 18:10:50
1860 forum posts
121 photos
I can easily weld it but didnt want all the hassle of prepping into 6mm steel. I would tig it to be sure of penetration, but then it would be a pig to redrill and tap.
remember its only 7ba
JasonB06/11/2012 18:20:40
Can't you drill it out to say 1/4" prep and weld in a pre tapped blind bush made from a bit of 1/4" rod.
J
Edited By JasonB on 06/11/2012 18:21:27
fizzy06/11/2012 18:30:42
1860 forum posts
121 photos
hi Jason - not a chance. The amperage required to get good penetration would obliterate the bush for sure. Im gona take my chances with the loctite, its screwed in pretty tight so even if there is a small initial leak it wont be long before it gets filled with boiler gunk and blocks up! (tiny fragments of rust etc).
Springbok09/11/2012 00:16:37
879 forum posts
34 photos
Hii Fizzy is it still pink??
S.D.L.09/11/2012 08:18:43
236 forum posts
37 photos
Posted by fizzy on 06/11/2012 12:20:09:
Why not silver solder a bush in.
Steve Larner
Dave Jones 109/11/2012 09:07:02
85 forum posts
5 photos
Sorry to hijack the thread, but I have a similar problem with a misplaced 1/8" hole drilled through a copper boiler. Could anyone advise if it would be safe to use a 1/8" solid copper rivet to fill the hole and then silver solder over it after it was fitted? If it makes a difference its a 3 1/2" gauge northumbrian boiler if that makes a difference.
fizzy09/11/2012 19:39:29
1860 forum posts
121 photos
that will be fine
