magpie | 29/09/2012 19:56:09 |
![]() 508 forum posts 98 photos |
Michael Gilligan | 29/09/2012 20:14:00 |
![]() 23121 forum posts 1360 photos | Derek, That looks very promising !! Any idea how many "fresh edges" you can expect to get from the circular insert ? MichaelG. |
Stub Mandrel | 29/09/2012 20:17:43 |
![]() 4318 forum posts 291 photos 1 articles | Excellent idea. Neil |
magpie | 30/09/2012 15:02:08 |
![]() 508 forum posts 98 photos | Thank you Neil, And Michael. I have no idea how many fresh edges,but i would think quite a few, if you were only taking small cuts. I have been using a 12mm shank tool on the lathe, that takes the same tips for a few years now,and i still have 8 tips left from a box of ten. 90% of stuff i do is brass or ally so not too hard on tools. When milling the pyramids, i faced up around 20 square inches of brass with no discernable wear on the tip, when checked with a X10 loupe. Cheers Derek |
Gone Away | 30/09/2012 18:33:04 |
829 forum posts 1 photos | Derek, is the profile tool insert HSS or carbide? If it's carbide, do you have any problems with the interrupted cut? |
Ian P | 30/09/2012 20:31:42 |
![]() 2747 forum posts 123 photos |
Posted by Sid Herbage on 30/09/2012 18:33:04:
Derek, is the profile tool insert HSS or carbide? If it's carbide, do you have any problems with the interrupted cut? Sid There is interrupted cut and interrupted cut, it all depend on how interrupted, speed, material, tip type etc. I have never found any problem with discontinuous cutting using indexable carbide tips. Today I turned 20mm square stainless to 12mm diameter and no drama was involved. I could imagine that doing the same with a larger size on really tough steel might be tougher but its done all the time in industry but probably done with the right tip. After setting up the material today in the 4 jaw, I took light cuts and got peppered with tiny fragments of stainless, so I used plan B and took all but a finishing cut in one (slow) pass. In reality it was no longer an interrupted cut, just a cut of varying width. Ian |
magpie | 30/09/2012 22:26:57 |
![]() 508 forum posts 98 photos | Sid, I think Ian has answered your question better than i could. As i got toward the tip of the pyramid, there was a lot more interrupt than cut, and after cutting 8 of those faces , the tip was still fine. Cheers Derek. Ian please check your PM's |
Gone Away | 01/10/2012 00:36:29 |
829 forum posts 1 photos | Thanks Ian and Derek. I have one of those profile tools sitting around doing nothing much - I'll give this a try. |
Pete | 02/10/2012 14:00:14 |
128 forum posts | I can't say if these types of fly cutters would be avalible in the U.K. But they are in North America. Their built by "New Generation". They do take a bit larger round industrial carbide replaceable tip, but that can be a good thing since various grades and coatings are avalible in those sizes. Unless you make a large error and badly chip or totally destroy the tip, their really cost effective. They might be a bit too large and heavy to be used in something lighter than a Bridgeport type mill since they can be adjusted up to a 6" diameter. Pete |
