David Clark 1 | 24/09/2012 16:07:42 |
![]() 3357 forum posts 112 photos 10 articles | Hi There I need a small ring rolling, steel about 3/32 to 1/8 inch (2 1/2 to 3mm) thick. About 55mm wide and 175mm diameter. Not quite full diameter would be fine. It is for a grinder guard. regards David |
Peter Tucker | 25/09/2012 20:17:55 |
185 forum posts | Hi David, Why not turn it from a piece of 2" galv pipe? Peter. |
Andyf | 25/09/2012 20:22:19 |
392 forum posts | Think you may be confusing the 55mm length with the 175mm (six and a half inch) diameter, Peter. Sorry I can't help, David; I've no rolling machine.. Andy |
Ian Welford | 25/09/2012 20:25:29 |
300 forum posts | Dave
try a piece of steel ducting. Air con ducting off cuts are quite cheap / free and galvanised often.
Regards Ian |
JasonB | 25/09/2012 20:32:22 |
![]() 25215 forum posts 3105 photos 1 articles | Does it really need rolling, can you not bend it around something of a slightly less dia or use the 3 points in a vice method. J |
Andy Freeman 1 | 25/09/2012 21:09:38 |
50 forum posts 33 photos | PM me with your address and I can post one to you tomorrow if you like, FOC. Will take only a couple of minutes to roll. |
David Clark 1 | 25/09/2012 21:32:19 |
![]() 3357 forum posts 112 photos 10 articles | Hi There All sorted thank you. I can't do it at the moment and I need it before next Wednesday. I don't have my workshop set up yet, that is what I am doing at the moment. I thought I had better get it done before the year since we moved was up. regards David Edited By David Clark 1 on 25/09/2012 21:32:39 |
