Nick Hopwood | 20/09/2012 14:30:01 |
31 forum posts | Can anybody tell me what taper is used in the headstock of a Harrison 140? The handbook says 3 morse but it obviously is not. Thanks. |
Keith Long | 20/09/2012 15:41:55 |
883 forum posts 11 photos | Hi Nick I may well be wrong about this but I think that Harrisons usually have a "bush" in the business end of the spindle and the 3MT taper is actually in that bush. Colchester do the same trick. On Colchesters the actual spindle taper is NOT a Morse taper but seems to be one of their own. Your best bet is to measure the end of the spindle with a DTI and see what the taper actually is. I've got the same issues with an old IXL Leader that I just acquired, it's headstock is a Colchester Master clone and I'm missing the spindle nose bush. The upside is that when i get round to machining one it can have whatever fitting I like inside! Keith Edited By Keith Long on 20/09/2012 15:42:31 |
Ian S C | 20/09/2012 15:50:56 |
![]() 7468 forum posts 230 photos | Just been looking up your lathe, if the bore is 1 3/8", and the bore at the spindle nose is 1 5/8", you will find its called a 4.5 morse taper. Its a modified standard MT, not sure if its MT 4, or MT 5, proberbly the thick end of MT 4. My Taiwanese lathe has a 5 MT spindle, with a 3 MT bush, I'd hate to have to pay for MT 5 tooling! Ian S C |
Nick Hopwood | 20/09/2012 18:03:04 |
31 forum posts | Many thanks for your prompt replies. Looking at the handbook again it does look as though there is a bush in the headstock. Looks like another project for the future! |
blowlamp | 20/09/2012 18:42:52 |
![]() 1885 forum posts 111 photos |
My Harrison M250 (D13 camlock spindle nose, 35mm through bore) has a reducer bush to allow a centre to be fitted. Your situation may be similar. Martin. |
michael cole | 20/09/2012 18:46:11 |
166 forum posts | Same here with my boxford. 4.5 MT to 3MT bush in the headstock. Still availabe new from boxford. |
KWIL | 20/09/2012 19:02:31 |
3681 forum posts 70 photos | Harrison M300 is MT5, tailstock is MT3 |
