johnsonbar | 14/08/2012 20:49:19 |
6 forum posts | I am planning to build the GHT boring bar, and wanted to get some feedback from previous builders. The design shows 2 threaded items: 1. a 9/32" X 40 fine adjustment plug type screw, and 2. a 3/16" X 40 tapered locking screw. Do you have to make both of these screws yourself, or is there a commercial source that has something close that can be modified to this design? Also, if anyone has any modifications or a better design altogether, please share your experience. Note: This thread is a continuation of a previous thread "TURNING BETWEEN CENTERS", which actually should have been titled "BORING BETWEEN CENTERS". This thread is about a boring bar design by George H Thomas, and described in his book "THE MODEL ENGINEER'S WORKSHOP MANUAL" on page 92. Thank you. |
JasonB | 14/08/2012 20:56:29 |
![]() 25215 forum posts 3105 photos 1 articles | You will have to cut them yourself as there are very few fixings sold in the ME form. They can either be screwcut on the lathe or using a readily available die. The reason for 40tpi is it gives 0.025" per turn the same as a micrometer though teh lock screw could probably be substituted for soemthing else. J PS if you work in metric then 0.5mm pitch may be better. |
Springbok | 15/08/2012 03:57:50 |
![]() 879 forum posts 34 photos | Sounds like the one Arand Tools sell but could be wrong Bob |
Russell Eberhardt | 15/08/2012 16:06:37 |
![]() 2785 forum posts 87 photos | Yes, you'll need to make the 40 tpi screw yourself. The complicated locking system, though elegant, isn't really necessary (IMHO). You can just fit a grub screw at right angles to the toolbit to lock it although you do have to be careful that it doesn't shift the toolbit. Russell. |
