Titius Bode | 10/05/2012 17:28:50 |
![]() 1 forum posts | We are having some trouble finding the best adhesive for bonding a plastic propeller to a stainless steel drive shaft. The opposite end of the shaft that holds the weight has been a success as we have a very strong joint that withstands 2500N of force before it breaks but our propeller and shaft joint is breaking at 160N. Nowhere near strong enough for what we want. Any advice? |
Russell Eberhardt | 11/05/2012 13:10:24 |
![]() 2785 forum posts 87 photos | It depends on the type of plastic. Some are notoriously difficult to bond to. You could try one of these Alternatively how about knurling the end of the shaft, heating it to just under the melting of the plastic, and pushing it intu an undersize hole in the plastic part. Russell. |
Stewart Hart | 11/05/2012 14:03:44 |
![]() 674 forum posts 357 photos | As Russell said a straight knurl will give you a good grip when I was an apprentice we made screwdrivers taht, and I'm close to completeing a resiprocating rotary engine that has its piston fixed by that method.
Stew |
Ady1 | 11/05/2012 15:06:02 |
![]() 6137 forum posts 893 photos | Undersizing can work well
I fitted an undersized aluminium cog to my backgear with no keys or anything else and it's done a great job. I cut a shallow thread in the bore so the material could squish as it was battered into place Took about 30 minutes to put it on with a bored out plastic drift and at times it handles some very high torque
Being plastic though, it's unlikely to have a lot of resistance to torque Maybe putting a metal insert into the plastic then put the metal insert onto the shaft would be stronger The further you can move the plastic away from the centre of the shaft the greater the resistance to torque issues you should get Edited By Ady1 on 11/05/2012 15:15:22 |
Jeff Dayman | 11/05/2012 16:22:00 |
2356 forum posts 47 photos | Titius Bode- What type of model is the propeller for? What is shaft diameter and engaged length in hub, and what is prop dia and max RPM? What is the prop made of? You may need to incorporate a positive drive feature on the shaft to hub joint. Look at photos of small aircraft for ideas on that. Adhesives are not generally recommended for these joints in model aircraft due to extremely high forces from rapid acceleration and deceleration. The strongest adhesives have max shear strength of around 3000 psi max. Joints with large surface area can be quite strong, but joints with small areas will not be. As others have mentioned, many plastics do not bond with any adhesives well. JD Edited By Jeff Dayman on 11/05/2012 16:22:36 Edited By Jeff Dayman on 11/05/2012 16:23:02 |
Weldsol | 11/05/2012 18:15:24 |
74 forum posts | As a thought what about threaded the shaft and prop which should work, obviously using the handing off the thread so it would tighten against rotation ( that is unless you want to reverse rotation direction if this is the case then you could also cross pin it)
Paul |
Jeff Dayman | 16/05/2012 22:19:12 |
2356 forum posts 47 photos | 6 days later, several good replies, and no response from OP Bode. Not good. JD |
