Meehanite Size ?
WALLACE24/04/2012 12:34:33
304 forum posts
17 photos
Hello all.
Just a quick question about the lumps of cast iron meehanite sold by our regular suppliers.
As it's not exactly cheap, I want to get pretty much exactly the right size -so does it have a hard skin that needs machining off and how accurate is the advertised size ? I've only about 2 or 3 mm over to play with and I'd rather not go up a size !
thanks.
WALLACE.
John Haine24/04/2012 12:50:05
5563 forum posts
322 photos
I have used the continuous cast bar from CES and found no trace of hard scale, a delight to machine. Remember that "square" bar has rounded corners though. Can't comment on accuracy but I think they specify a tolerance. Also can supply sawn lumps that of course have sharp corners, but not very square.
JasonB24/04/2012 13:20:58
Just measured up a few lumps that I have, 40,50, 60 & 70 all 0.2 mm to 0.5mm oversize depending where the measurement was taken, mine were also all from CES and I've not found any hardspots in them.
J
KWIL24/04/2012 14:08:16
3681 forum posts
70 photos
If you want to end up with a specific finished size, you can always state this and ask for the next oversize available.
WALLACE24/04/2012 19:07:13
304 forum posts
17 photos
Thanks everyone - I think for the case of a few pounds, i'll stretch to the next size up - if nothing else, it gives me a smidge more ' mistake' room - so to speak !
W.
Stub Mandrel24/04/2012 20:02:28
4318 forum posts
291 photos
With round bar there is sufficient machining allowance on the quoted size, the square bar has about 1/4" radius corners but is oversize so you don't lose as much as it sounds.
JasonB24/04/2012 20:15:06
Not according to what I measured, all 4 sizes of round bar only had 0.2 to 0.5mm to play with. Maybe you are thinking of cast bronze which tends to have 1/32" allowance.
Also just checked some rectangular CI
40x80 nominal measured 40.2mm x 80.6mm and 50x25 nom measured 50.1mm x 25.15mm hardly oversize at all.
J
WALLACE25/04/2012 18:11:41
304 forum posts
17 photos
I've bitten the bullet - and gone for a lump 90 x 90 x 80. I'll measure it when it turns up and post the results !
W.
Chris Trice25/04/2012 22:27:40
1376 forum posts
10 photos
I made up a longer topslide for my lathe using Meehanite rectangular block and although I had a good extra 3/16th all over, I did notice that when cut to length, some of the material inside looked slightly darker towards the surfaces, bit like a rectangular stick of rock. When I machines the outer surfaces down, there was no discernible sense of the material near the surface being any harder but you could still definitely see a very slight patchwork of darker material. I can only put this down to cooling rates at point of manufacture and the iron changing it's form slightly as a result. In machining terms, it doesn't appear to have altered the properties of the material to any degree I can notice.
Edited By Chris Trice on 25/04/2012 22:27:57
