David Blight | 19/03/2012 14:56:45 |
12 forum posts | I should be grateful for advice on removal of jacobs chuck from Fobco Star 1/2" bench drill, there is excessive run out which i hope is in the chuck. There is no provision for driving a taper through the quill, so I assume it is not a Morse Taper. It could be a threaded or jacobs taper, how do i find which it is? When identified, what is the correct course of action? David |
Ian Hewson | 19/03/2012 15:02:30 |
354 forum posts 33 photos | Hi David You should find a threaded collar behind the chuck, with tommy bar holes in it. Chuch is removed by holding the chuck stationary and screwing the collar down to force it off of the taper. That is how my two drills are arranged. Regards Ian |
Cornish Jack | 19/03/2012 16:23:19 |
1228 forum posts 172 photos | David Assuming all Fobco Stars are similar, my chuck is held on solely by the taper (Jarno-ish?). It has removed itself a couple of times due to drilling forces, so, maybe a judicious tap, thump or similar with a Birmingham screwdriver may well suffice. Probably the 'professional' method would be opposing wedges in the space above the chuck? Rgds Bill |
NJH | 19/03/2012 16:55:35 |
![]() 2314 forum posts 139 photos | David The best way is to use these :- http://www.arceurotrade.co.uk/Catalogue/Chucks/Wedges-Drifts Cheers Norman |
RobC | 19/03/2012 19:40:32 |
54 forum posts 3 photos | David, I had the same issue, but I think I zoinked the bearings when I disassembled it! Although a new chuck improved things signifiantly. The best way is as the guys note, with the Wedges. I found that a couple of flat plates held above the wedges gave me plenty of space to get the leverage working. I used a G-lamp to slowly apply force. Remember to put something to catch it in underneath or it will drop on your foot like mine did! Rob |
David Blight | 19/03/2012 21:28:45 |
12 forum posts | Thanks for the advice Ian, Bill, Norman, and Rob. I found that I needed to loosen the socket cap screw in the collar around the bottom of the quill, and drive this collar up the quill away from the chuck by about 1”. This revealed the threaded collar, which as Ian correctly recommended simply unscrewed to force the chuck off the taper. David |
John Comfort | 30/01/2014 11:02:31 |
1 forum posts | Fobco provided a 'screw down collar' on the Fobco Star drill to facilitate chuck removal. Please don't attack this precision tool with hammers as this will not do the bearings any good. The chuck (Jacobs 34-06 or equivalent) is fitted to a Jacobs JT6 taper at the bottom of the quill shaft. To remove the chuck lower the chuck etc by about 2" and clamp it with the side lever. Remove the depth stop stud. Loosen the collar (7/32" AF hex key) which attaches to the depth stop and then wiggle it up to reveal the collar which is just above the chuck. The collar is knurled and has a couple of holes in it for a 'C' spanner. If you do not have a 'C' spanner which fits protect the collar with a strip of soft metal (I used an old copper pipe clip) and attach a mole grip. Insert a 5/16" bar into one of the chuck key holes (If older chucks are opened up the bar will go right in - new ones are not drilled thro' |
Patrick Carnegy 1 | 18/03/2014 22:40:15 |
8 forum posts | Could anyone please tell me the name, or code for, the correct cream paint colour used on most Fobcos? Any ideas about where to obtain it?
Martin Walsh 1 | 18/03/2014 23:04:32 |
113 forum posts 2 photos | Posted by Patrick Carnegy 1 on 18/03/2014 22:40:15:
Craftmaster paints do a very close cream paint it is also top quality
Best Wishes Martin
Patrick Carnegy 1 | 19/03/2014 14:04:51 |
8 forum posts | Thanks very much, Martin. Can you please help further with the name or number of the cream paint which I should order from Craftmaster? Al best, Patrick |
Martin Walsh 1 | 19/03/2014 20:36:40 |
113 forum posts 2 photos | This is the cream taken off craftmasters website I think it is a good match If in doubt contact [email protected] and they will match any color you want Best Wishes Martin Edited By Martin Walsh 1 on 19/03/2014 20:38:20 |
Patrick Carnegy 1 | 19/03/2014 20:51:25 |
8 forum posts | Thank you very much, Martin. That colour looks good to me and I'll pursue it with Craftmaster. I've just made the happy discovery that Craftmaster are in Over, Cambs, no more than about 5 miles north of my home in Elsworth. So I'll drive over and see them! Present paint colour is a horrible bilious green, quite unworthy of this fine machine and crudely applied. best wishes, Patrick
