Alan Worland | 16/03/2012 20:49:57 |
247 forum posts 21 photos | My current steam engine calls for a brass sheet wrap around the cylinder as lagging but I would prefer to use timber. I have aquired strips of a suitable timber material which measures about 5 or 6mm wide by a couple of mm thick which I was proposing to hold in position with a couple of stailess steel straps. My question is, is this the correct way to do this? as I am a bit concerned that the wood will move with heat/damp and not look so good! Did I ought to make the strips out of something thicker which more followed the 'cotton reel' type shape of the cylinder casting? Any guidance/advice wout be very welcome
Alan |
Springbok | 16/03/2012 20:59:12 |
![]() 879 forum posts 34 photos | Hi Allen, A number of questions, firstly what is the steam engine and it's scale. . I have been doing a lot of research into moldable lagging materials of recent and hope to present this to all on forum. Bob |
Stub Mandrel | 16/03/2012 21:32:02 |
![]() 4318 forum posts 291 photos 1 articles | Tom Walshaw used to stick the lagging strips to thin material (such as an old cotton hanky) to keep them in line. I just glue them on one at a time with superglue. Perhaps not the neatest job, but they haven't moved when run on steam. 1/12 scale, so about 1 1/8" diameter at the flanges. Neil |
Alan Worland | 16/03/2012 22:07:13 |
247 forum posts 21 photos | Bob, my model is a horizontal engine, 1 1/2 bore and 2 1/2 stroke and I would say the diameter of the cylinder flanges which will take the lagging is about 2 1/2 diameter. I did even consider filling the recessed part of the cotton reel shaped casting with car filler or JB Weld so as the strips would have something to stick to! Neil, have you stuck them directly to the casting? or did you use a membrane? and are they oiled or varnished?
Alan |
Alan Worland | 16/03/2012 22:37:50 |
247 forum posts 21 photos | Thanks Michael, I have myself used stainless steel on a previous engine (in my photos) which I thought looked quite good and I have an early Stuart engine which is lagged with blued steel which also looks good. I do have some sheets of SRBP which I could have a play with but it might look a bit 'bland'? The Tufnol sounds the better bet as it has the woven texture to it. Is there a filler which might survive stuck to the cylinder under my timber?
Alan |
Springbok | 17/03/2012 04:20:43 |
![]() 879 forum posts 34 photos | Hi What I was thinking about doubt it would be of any use to you but the cotton strip idea sounds good now I have seen a pic.. Bob |
JasonB | 17/03/2012 07:30:49 |
![]() 25215 forum posts 3105 photos 1 articles | I';ve used the stick it to an old hanky method, just lay the fabric onto a sheet of polythene(non stick) coat with exterior pVA wood glue and lay teh strips onto it. When all is dry trim to size and wrap around cylinder then retain with metal straps. The minnie in my avitar has balsa strips done this way below the brass clading sheets and this beam has the wood exposed.
If you want to fill the space and are going to steam run it then fill the void with an insulating material like Kaowool. If you want a filler that will take the heat then JB Weld will do but won't actually add any insulation value. J |
Richard Parsons | 17/03/2012 09:08:55 |
![]() 645 forum posts 33 photos | There was some stuff used by jewellers which you mixed with water and slapped on jewellery to protect it when silver soldering. I think H.S. Walsh sell it (usual disclaimer) Rdgs Dick |
Stub Mandrel | 17/03/2012 19:32:26 |
![]() 4318 forum posts 291 photos 1 articles | Tom Walsahw insisted that most lagging material was a waste of time in small szies, but balsa (if kept dry) was good. In answer to the question, I just glued my strips direct to the cylinder with no other lagging. Naughty, but it worked. The original has wooden lagging (note my model isn't accurately to scale... more sort of inspired by!) Neil |
Brian John | 08/07/2015 08:24:33 |
1487 forum posts 582 photos | Has anybody else used superglue to glue the lagging to the cylinder ? I would not have thought it would tolerate the heat very well. |
Neil Wyatt | 08/07/2015 09:33:45 |
![]() 19226 forum posts 749 photos 86 articles | 'Service temperature' is typically about 82 degrees C, but I don't run that engine on steam for long periods - I've only steamed it 2 or 3 times, it usually runs on air. The brass strips would stop the strips falling off, the glue just held them neatly in place while I fixed the strips, I suppose. Neil |
Brian John | 08/07/2015 10:48:08 |
1487 forum posts 582 photos | Thank you for that information : I will stick with my plan of using JB WELD. What colour red is used on that engine ? Edited By Brian John on 08/07/2015 10:49:50 |
Neil Wyatt | 08/07/2015 14:10:37 |
![]() 19226 forum posts 749 photos 86 articles | It's Humbrol Crimson, if I'm not mistaken, always looks more like a dark maroon to me. Neil |
