Tractor man | 15/03/2012 20:06:52 |
426 forum posts 1 photos | Hi Folks, I have just read the article on rebuilding a Raglan 5 inch and wondered about the wisdom of fitting a reverse to the motor on a lathe with a screw on chuck? I have a 5 inch myself and rebuilt it to similar standards but left the motor drive as original as possible. I was considering a new motor and drive package which obviously includes the capability to reverse motor direction and I would appreciate any opinions on whether the chuck would be likely to screw itself off. A brilliant job on the lathe by the way which looks good and will do some great work. Regards Tractor man |
chris stephens | 15/03/2012 23:54:27 |
1049 forum posts 1 photos | Hi Tractor man, The reversing VFD seems to work just fine on a Myford, so should be equally fit for a Raglan, just set the ramp down time to somewhere about 2 seconds. As they say, "it works for me" chriStephens. |
Russell Eberhardt | 16/03/2012 15:12:00 |
![]() 2785 forum posts 87 photos | It depends what you are going to do with the motor in reverse. I only use reverse when screw cutting metric threads on an imperial lathe to go back to the start without disengaging. I wouldn't try cutting in reverse. Russell. |
colin hawes | 16/03/2012 15:46:58 |
570 forum posts 18 photos | Like Russell I fitted my old imperial lathe with reverse to facilitate cutting metric threads . It is also useful for unscrewing dies. This is a big lathe that is very tedious to turn by hand. If the ckuck is just screwed on with a gentle nip there should be no trouble.The only time i hve known a chuck unscrew is when a three phase motor was snapped into reverse whilst still rotating forward. I would not try machining cuts in reverse Colin |
