dial matting
george hoggard11/03/2012 17:13:10
3 forum posts
Can anyone help me with the problem of dial matting? , a lost art at least I thought so until I saw a hand made bracket clock with superb matting! I was told it was done by a firm in the clock trade full stop.It looked as If It had been etched with acid and it was very crisp and regular I am going to try ferric chloride as used for etching circut boards .the other Idea is using a muliple punch but this causes the brass to sink . Any suggestions would be helpfull
All the best George
Richard Parsons11/03/2012 17:57:41
645 forum posts
33 photos
An old clock making friend used to do this. He used a set of wheels in a in a fork with a handle.
He made his by straight knurling a short length of silver steel using a fine knurl (actually I did it for him in the Myford). This cylinder was first drilled through the centre. He then cut thin slivers of the knurled steel which he faced up on his Boley and machined the edges so that had the same angle as the knurl. The disks were hardened and tempered. Four or five were fitted into a fork with a pin through the hole. The Handle was quite long and had a sort of curved end like the butt of a gun at the top end. To decide the diameter of the rollers I had to work out the distance apart of the lines of the knurl and their height I cut a full set of knurl cuts in the bar.
To use the thing, he secured what he was going to mat onto a thick-ish bit of ply wood which he secured to his heavy bench. He would then sit down put the wheels against the work piece and put the ‘stock to his shoulder, push down and rock to and fro guiding the rollers with his hands.
He brushed the work piece off now and again with a brass brush –from a shoe shop-.
Hope it helps
Rdgs
Dick
NJH11/03/2012 18:46:39
2314 forum posts
139 photos
Hi George
A good question! I have a clock dial to matt and I propose to use an engraving tool similar to:- this
I must say I have been putting it off for a while but I have tried it on a 2in square scrap piece of brass and it seems to give an acceptable finish. If you do proceed with the chemical method please post a picture or two. I would be a bit concerned that it might not be sufficiently "rough" and perhaps rather even. I don't think a little irregularity is out of place in a hand made clock.
The books I've read say that the punch method can distort the plate with all the consequent problems of flattening it again.
Any other advice gratefully received - don't want an expensive mistake!
Norman
george hoggard12/03/2012 20:10:13
3 forum posts
thank you for the information, I had a go with the ferric chlord and added some citric acid with it as I'd found out it would vastly improve it! Sadly it was no good.for my dial. I think my next . attempt will be on the lines of the roller as mentioned by Richard Parsons. I had tried that way before with no success but I think my wheels were to wide and needed to much effort on my part. _ Till the next time George.
Ian S C13/03/2012 10:19:36
7468 forum posts
230 photos
How about a light sand blasting, Badger, the air brush makers also make a little sand blast unit. I would use a soft grit, and a stecil type mask, to protect anything you don't want frosted. Ian S C
blowlamp13/03/2012 10:27:56
1885 forum posts
111 photos
A needle scaler wink
Martin.
johnp1013/03/2012 11:56:53
25 forum posts
4 photos
Hello M r Hoggard.
If you will kindly contact me on [email protected] I will send you details of a system of dial matting described by Alan Timmins which I tried and found it gave an excellent result.
Regards.
John Parslow.
YouraT29/03/2020 22:43:35
83 forum posts
22 photos
Hi.
Coming I realise *very* late to this thread, I'm reading Richard's description of the tool his friend made and I'm struggling with the phrase
....machined the edges so that had the same angle as the knurl....
as it's a straight knurl...
Richard - if you're reading this - would you possibly explain perhaps differently so I have a chance of understanding, or maybe sketch something....?
Here's hoping!
Thanks,
Youra.
Bill Davies 229/03/2020 23:24:35
357 forum posts
13 photos
Youra,
Looking at Richard's member postings, his last was on 27July 2012, so I don't think he will answer you. I think he means chamfer the edges to the same angle as the knurls (like pressure angle on gears). This would leave points which would I suppose give a matt effect when rolled repeatedly across the surface in all directions. It does seem like etching is an easier option.
Bill
YouraT30/03/2020 17:59:11
83 forum posts
22 photos
Bill,
I wasn't too hopeful of a reply, but thank you for your suggestion, which does make sense.
The problem I have with etching is the dimensions of the features - I think they would be too small if done chemically to look as they did on older clocks, but I'll try a few options and see.
Thanks again,
Youra.
