Bob Hepple | 10/03/2012 14:03:47 |
19 forum posts 1 photos | Hi I am about to put a Newall DRO on my myford super7. I got the kit from Newall for the Myford, I get the feeling that the sadle lock is going to be in the way and feel that its probably best putting the lock at the front of the saddle. Can anyone point me in the direction of what's going to be involved into doing this before I start dismantling ??? or any information articles on moving the lock .
Thanks Bob |
KWIL | 10/03/2012 14:39:32 |
3681 forum posts 70 photos | Bob,
PM me with your email address and I will send you photos of how I moved the carriage lock onto the front, much more useful and more to hand (as well as leaving the back clear for yourI Newall system. I can show you tidy installation shots of the Newall System (I have 4 on different machines)
K |
John C | 10/03/2012 14:48:19 |
273 forum posts 95 photos | Hi Bob, I too have the saddle lock on the front of the apron. I used the idea in MEW May 2010, no 163 in the archives. The lock uses the thread dial mounting and works very well indeed. More photos in my album under 'Super 7 saddle lock'. Rgds, John Edited By John Corden on 10/03/2012 14:51:14 |
Bob Hepple | 10/03/2012 20:13:49 |
19 forum posts 1 photos | John thanks for this will look at the article thanks, |
Andrew Moyes 1 | 10/03/2012 20:45:31 |
158 forum posts 22 photos | This is where Myford put the saddle lock when they installed a Newall DRO... |
Bob Hepple | 11/03/2012 19:07:02 |
19 forum posts 1 photos | Andrew thanks for the picture very helpful not far from kwil's position I think Im going to try and copy this do you know id they used the same parts just re positioned. |
Andrew Moyes 1 | 12/03/2012 08:50:20 |
158 forum posts 22 photos | Bob - as far as I can tell using a torch and mirror, it's the same arrangement as was on the back of the saddle of my previous ML7. That is, a thick disc of mild steel overlapping the underside of the shear with an off set tapped hole for the bolt. Presumably it sits in a counterbored hole to suit. Andrew |
Nigel Bennett | 12/03/2012 12:58:26 |
![]() 500 forum posts 31 photos | I moved my rear-mounted saddle lock no problem about half an inch to the right IIRC to clear the Newall DRO on my S7. I made up a little jig to ensure that the drilled hole went through vertically and in the same position relative to the bed. I have a Kipp handle there as a tool-free lock (rather than the hex head Myford supply.) Somebody advertises them on eBay. Occasionally it does foul the tailstock, but it's not too difficult to rremove it temporarily. The front-mounted lock does have its attraction, but I don't think the Kipp type handle would fit without fouling things so you'd need the spanner to hand or the low-height lock as in the photo above.. Edited By Nigel Bennett on 12/03/2012 12:59:08 |
Terryd | 12/03/2012 13:40:12 |
![]() 1946 forum posts 179 photos |
Posted by Bogstandard2 on 11/03/2012 09:51:55:
For those who own the more popular far eastern machines and come across the same problem, here is my way for fixing the problem. http://www.atfreeforum.com/chesteruk/viewtopic.php?t=389&mforum=chesteruk
John Hi John, The provider at your link appears to have gone offline, do you have another source for your mod? Best regards Terry |
geoff | 16/05/2012 16:22:42 |
29 forum posts | has anyone fitted a dro to a peatol mill table if so could i have some pics on a method of doing it geoff |
geoff | 16/05/2012 16:22:43 |
