QD Chuck for Mini Lathe
VC19/02/2012 14:16:02
46 forum posts
10 photos
Hi all
This is hardly a question more like an answer to the problem of those pain in the butt 6mm nuts that hold the chucks on the little(yellow) lathes.
The helicoils are not the best of fits but with a little loctite they have lasted for a few years now.
Have not seen this done before
Hope that gets me a noddy badge or free subscription QD ChuckCap screw6mm Helicoil
Bernard Laycock 119/02/2012 17:03:25
32 forum posts
I may be thick, but I don't understand what you've done. In the photos, I can't see that anything has changed. Could you help with a bit more detail?
Bernard
blowlamp19/02/2012 18:49:59
1885 forum posts
111 photos
Graham.
I'm glad you can make it out, 'cos I've a list of adverts running straight through the text (yours included).
Martin.
Gone Away19/02/2012 18:52:29
829 forum posts
I assume he's replaced the usual stud/nut arrangement on these chucks by drilling through to the front of the chuck, counterboring on that side and using a SHCS from that side.
Presumably the helicoils are used in the spindle flange holes (the picture isn't that clear).
JasonB19/02/2012 19:06:41
Its likely to be a front mount chuck so no drilling required.
Just tap the flange for the helicoils and fit same
VC19/02/2012 19:16:25
46 forum posts
10 photos
Hi All
I did not explain that very well sorry..First prize must go to Mr Graham Meek.
Thats what I did
Thanks Graham
Stub Mandrel19/02/2012 20:34:01
4318 forum posts
291 photos
Alternatively - do the roller bearing modification, and get an extra 5mmm of space behind the mounting flange.
Simples!
Bernard Laycock 119/02/2012 22:41:17
32 forum posts
My machine has been fitted with tapered bearings and fitting the nuts is much easier. Don't the roller bearings make a fantastic difference to the performance.
Bernard
Stub Mandrel20/02/2012 19:39:27
4318 forum posts
291 photos
I'm very happy with the roller bearings, although it seems mine was happier than most with the ball bearings.
VC20/02/2012 20:57:54
46 forum posts
10 photos
Hi glad to hear that there are happy chaps with the roller bearing mod...
Did a timed test to-day 40 seconds 3 jaw off and four jaw on.
Thats what I was going on about
VC
