Member postings for VC
Here is a list of all the postings VC has made in our forums. Click on a thread name to jump to the thread.
Thread: Arduino CNC Board
16/04/2021 11:17:49
Hi Boys and Girls
This is my go to place when all else has failed.
Need to buy the small jumper connections that are used to set the "steps" on the CNC Shield . Can find them with the complete board, but not by themselves.
Thanks in advance
Thread: Stand alone controller
12/05/2019 15:34:24
Hi All
Have bought this stand alone controller and managed to get it to work
via three 6065 drivers.
Cant find any manuel So some help please this has a slot for an SD card
Have written a very simple code starting and ending with % as was suggested in the add
get an error ERR_TIMEOUT
any help would be great
Thanks
12/05/2019 15:19:19
Thread: z-.006
23/03/2019 18:10:19
Hi All
Cutting Perspex with a very small cutter so needed to do 5 cuts at increasing depths machine is run from GRBL so started of with Z-.006 then added .020 to each run so next run would be at Z-.026,.046,.066,.086, .106 nothing magic there except the bugger would do the-.006 then jump to .086 that broke the tool
So started again Z up off the work same thing kept missing -.126 too -..066
Only way I managed to fix was to replace all the 6 with 5 then worked fine like to know the problem
Cheers
Thread: Connecting Rod
16/10/2018 16:06:07
Thanks very much for the reply's
Looks like 303 is the way to go but nobodies is saying where to get it from
Mac has 316 so if I can't get the 303 will give that a try
Cheers
15/10/2018 17:49:29
Hi all
Some advice please
Want to try and use my home made CNC mill Mk I Steig
to make a connecting rod for a 3 1/2 loco
Would like to know what SS flat bar to buy Size 1/4 *1 *71/2
and were to buy it
Have looked on Flea Bay 316 Marine grade will this be OK or to hard ???
Thank you
Thread: AC Motor 4 wire
11/02/2018 19:17:00
Thanks for the reply's
Top of my head nice and brown and not smelling that great.
Have had a look at my photos and there are none of the inside of my shed or the seven sockets
plus extension lead.
Not saying that I don't have multi plug sockets but only run one thing at a time.Seemed a good way
to save time ???
So unless Google Earth has taken the time and trouble to "stalk" me and my shed
Must just be MAGIC.
No help with the wiring yet
11/02/2018 14:49:14
Hi to all the "Sparkies"
Have fitted a ZP Mottori Elettrici 1/4 hp motor to my Quorn .
Need the beastie to run forward and reverse.
Has four wires coming out two green and two blue and a capacitor.
Motor runs in both directions but needs to be hand spun to start and the "fun" part is if I touch anything metal in the shed eg steel bench I get a shock
So help please with a wiring diagram
Thanks in advance
Thread: G code
04/05/2017 17:19:21
Have had trouble with G2/G3 on a odd shape and just ended up plotting in the x-y.
Saved a lot of hair pulling and lying awake half the night
Thread: Number plate
12/01/2017 16:53:08
Bit like looking up a word in a dictionary that you cant spell.
The plastic I'm looking for is not the stuff that you can buy in the DIY stores as this just cracks.
So still in the dark.
Thanks to all
12/01/2017 09:31:18
Hi all.
Just a quick one
What are motorcycle number plates made of ?
Find them very easy to work with eg bend drill cut..
But a real bugger to get the reflective bit off
so would like to buy some before it becomes a number plate
Thanks
Thread: Mini Mill Control Board
08/01/2017 19:31:56
Thanks Les have seen that diagram but does not turn a light on for me my neighbour is a hottie on electronics so he has repaired the board so don't want to let the smoke out
and thanks to John but once again not making any sense to me
What I need and would like if someone has the same X1 mill where all the wires go
board has gnd know what wires to put there L1 and L2 not sure about these two the "pot" has a a three plug so thats sorted two other wires with k1 and k2 so ok there two wires left on switch 4 and 8 too A+ and A- so thats ok
now just left with brown and blue 6 of the little buggers 2 from the mains and 4 from the EMI Filter
Thanks for the replys
08/01/2017 16:40:44
Hi to all
Once again in need of help on Mini Mill control board.
Nothing broken this time. Not being very good at electrics. Made note of where all the wires connected from switch. motor, mains and EMI filter.to the control board.
Then managed to lose the note.
Have spent hours looking up a wiring diagram that I could understand but just managed to get older.
HELP any body out there willing to put me out of my misery
Thanks
14/12/2016 19:29:16
Thanks to all for the replies.
Yes a new board would sort my problem.
Rather an expensive way. So can this toroidal be bought and where from.
To reply to Mr Rudd no other unrevealed failures
Just an idiot with a 12 mm drill in the lathe trying to make a hole in the new plastic box
SNATCH end of the little beastie
14/12/2016 17:38:38
Hi to all.
I have managed to destroy the "Whats this " Please don't ask how.
But would like to know if this can be bought and where from
Thankyou
14/12/2016 17:35:06
Thread: Stepper settings
01/03/2016 13:11:03
Thanks All
Yes bigger steppers would be better
But still think I would have the same problem
Need to add code X.050 and watch the stepper do ! rev
01/03/2016 13:07:37
01/03/2016 12:46:09
01/03/2016 10:14:33
Thanks for the prompt reply Emgee
The arduino has been "flashed" with GRBL
sounds like I know what I'm talking about just a little parrot talk
Testing on the mill. had too up the voltage to 24v
Thanks again
