Shesto cadet lathe
colin beighton23/01/2012 18:02:18
18 forum posts
Also known as a Connect 123 lathe.?
I rescued one recently and have it polished to a nice sparkle. Now I need two bits of (simple) electrical information. Can anyone help?
Ady123/01/2012 19:11:16
6137 forum posts
893 photos
Is that a CNC unit
Like the Denfords?
colin beighton23/01/2012 20:39:42
18 forum posts
Hello Ady 1. If you are thinking of the Denford ORAC then the answer is no. This is a smaller lathe with a round bar for the bed.
blowlamp23/01/2012 20:41:25
1885 forum posts
111 photos
What do you want to know?
Springbok24/01/2012 06:48:24
879 forum posts
34 photos
Everything I look at tells me that this is a CNC machine was it you that posted for help on the CNC forum
As blowlamp says what do you want to know
colin beighton24/01/2012 07:00:57
18 forum posts
Good morning blowlamp.
1. The big driving motor for the spindle is supplied from it's own circuit board which has terminals for armature and field etc. How is the speed varied? Do you feed a digital or analogue signal into some of the other terminals? Do you need to have the tacho connected also?
2.The two stepper motors are made in Italy (MAE Offanengo) and have 4 pairs of wires. The wires of 2 of the pairs are joined together. How do the wires connect to the coils inside the motor?
Les Jones 124/01/2012 08:45:52
2292 forum posts
159 photos
Hi Colin,
I will start by asking Ady1's question again. Is this a CNC lathe ?
If you trace out the schematic of the main motor control board I should be able to work out how the speed is controlled and if it needs speed feedback and in what form.
You should be able to identify the connections to the stepper motors using a multimeter.
This webpage will help you to identify the type of winding on the stepper motor.
Les.
Ady124/01/2012 09:39:04
6137 forum posts
893 photos
I have a lot of old cnc piccies, obsolete denfords and emcos, but none of mine ride on circular ways
Is there a tailstock and is it on circular ways?
Would be interesting to see a piccy
The Emco compact 3 is the closest I can find
colin beighton25/01/2012 15:26:22
18 forum posts
HI all,thanks for your interest. I'll tell you what I know about this lathe,or rather what I think. I may have got it all wrong.
The bed is a bar diameter 1.5 inches which protrudes 19 ins. from the headstock. The carriage and tailstock both ride on this.
It started life as a Connect 123 or 121, possibly in USA. They were bought in by Shesto engineering who did some work on them and rebadged them as the Shesto Cadet. They were CNC lathes. The original software ran on the old BBC Micro computer but was specific to this and does not transfer easily to modern computers. Also the motor drivers run in the old resistance limited mode. So I would plan to scrap all that, keep the motors and get new drivers and software. I expect that would mean a new driver board for the spindle motor as well.
There is not much information about them on the net and the little there is, is from way back. Perhaps they did not sell well?
Thank you Les for that link. It should keep me out of mischief for some time!
John Stevenson25/01/2012 23:40:00
5068 forum posts
The Conect [ one L ] range of CNC machines were UK based.
They were started in Long Eaton, Derbyshire by two guys, one I have forgotten his name and the second was Alan Timmins the clock guy.
They started off with a lathe based on the ML10, moved onto a mill based on the Rishton and then sold the company. At some point it was based in Ireland and routers had been added to the range.
Also at some point in their life Conqueror Engineering who are still in business supplied hardware for these machines.
John S.
Ady126/01/2012 00:39:15
6137 forum posts
893 photos
Is this it?
John Stevenson26/01/2012 00:51:56
5068 forum posts
The that's the one based on the ML10 lathe.
John S.
Ady126/01/2012 00:57:16
6137 forum posts
893 photos
If there are software related issues it might be worthwhile asking on the Yahoo sites
BBC basic, DOS etc there's quite a few retro language places around
colin beighton26/01/2012 10:26:38
18 forum posts
Good morning each. Thank you John S. for setting the record straight. I guess Alan Timming's involvement explains the watchmaker style round bed.
Re the software problem,your links give a lot of new information and open new possibilities. Very interesting!
Thanks everyone for your helpful input. Best wishes to all. Colin.
