Clive Hartland | 16/01/2012 21:05:08 |
![]() 2929 forum posts 41 photos | I have just bought some stainless steel 5mm shaft and its not round, put in the triple plain bearings and it catches as it is turned.
Measuring it shows a slight ovality but its hard to measure.
Does anyone know of where I can get precision ground 5mm st steel shaft?
I have looked at HPC but no luck there.
jason udall | 16/01/2012 21:49:36 |
2032 forum posts 41 photos | maybe smiths metals? Poole 01202893712 RS? 01536 201201 Rs may be better free del. Smiths cheaper by foot but add carr... |
Weldsol | 16/01/2012 22:05:28 |
74 forum posts | You could look at the CNC parts suppliers as they offer stainless for the linear bearing shafts. The only thing is it's very hard but is machineable with carbide tipped tooling
Paul |
S.D.L. | 16/01/2012 22:07:03 |
236 forum posts 37 photos | Its a common problem with center less grinding and needs a mic with a vee anvill to detect as it can measure the same at any position with a std mic. See here. And here You might be able to detect in raw stock by rotating in a vee block with DTI mtd. Steve Larner |
Clive Hartland | 16/01/2012 22:09:25 |
![]() 2929 forum posts 41 photos | I will look at the RS cat. tomorrow at work, thanks for your help.
jason udall | 16/01/2012 22:20:32 |
2032 forum posts 41 photos | other smiths msybe local to you. |
jason udall | 16/01/2012 22:27:23 |
2032 forum posts 41 photos | btw how out of round...guess enough to foul We used to use "gauges" with tenth micron resolution with centerless grinding looked round on them but wouldn't turn between mic anvils. |
jason udall | 16/01/2012 22:27:28 |
2032 forum posts 41 photos | .. [can not find way to delete duplicate post] Edited By jason udall on 16/01/2012 22:33:24 |
John Haine | 17/01/2012 08:25:33 |
5563 forum posts 322 photos | Try typing rswww.com into your browser - much easier than using their catalogue |
David Colwill | 17/01/2012 09:39:11 |
782 forum posts 40 photos | Is this condition described as obround? Dave. |
