spark eroder
norman royds 110/11/2011 14:15:01
4 forum posts
Hello
Does anyone have details of design of the mechanical part of Mike Napps spark eroder. That was on show at the recent Warwick Show
Norman
Gray6210/11/2011 15:12:49
1058 forum posts
16 photos
Hi, if you are a member of SMEE, Mike will gladly share the details of the device.
This is not a simple design and requires the programming of a microprocessor.
It is a very efficient design however, there is another route.
Ben Flemming has produced 2 designs for an EDM, one is RC based and the other is a more advanced pulse design, both of which use readily available components and do not require a micro or any programming.
Search Yahoo groups for EDMHomeBuilders for more details or PM me, as I have both of the books and PCB's in build if you require any further info
regards
Graeme
wotsit10/11/2011 16:39:37
188 forum posts
Not sure if I have the correct reference, but Mike Kapp (with a K, not N), published a simple EDM design here not long ago - I built a version which works well enough for me.
It is not a processor controlled system - uses a simple CMOS control circuit. The series of 4 articles gives all constructional details, and the thinking behind it, if you want to change things.
Jack Knapkin25/08/2013 18:41:42
1 forum posts
I have seen similar postings for a while now and have tried to build my own machine without success. I came across Pear Tree Engineering ( www.sparkeroding.co.uk ) to whom I posted a shaft with a broken tap which they removed sucvessfully.
It seems an easier and cheaper way than trying to build a machine whose performance may be doubtful.
Hope information is useful, Jack
Michael Gilligan26/08/2013 08:57:24
23121 forum posts
1360 photos
Posted by wotsit on 10/11/2011 16:39:37:
Unfortunately, that link is returning 404 [File Not Found]
JasonB26/08/2013 09:20:34
Probably as the post is 2 years old!! MEwebsite has been changed about recently with a lot of projects taken off and only available on DVD
Michael Gilligan26/08/2013 10:48:04
23121 forum posts
1360 photos
Thanks for the info. Jason
Dunc26/08/2013 14:58:53
139 forum posts
"...lot of projects taken off and only available on DVD"
Hoping - and I apologize for my intrusion on the thread - the moderator would provide details about the dvd (what it is, contents, how to order, cost, etc). Thank you
JasonB26/08/2013 15:09:22
PM sent
