Hobbymat lathe speed control.
Variac, Rheostat.
Chippychap01/05/2011 10:43:28
11 forum posts
I have an H/M MD65.
With all the talk of variable speeds applicable to working different metals I wondered if, instead of gear changes, you could alter the speed of the motor to achieve the same result.
As a pup I well remember rheostats, apparently now called variacs.
Is this method a "runner" or does restricting the flow of current to a motor just not work?
You can see that I know less about electric motors than I do about lathes but the thought of turning a thread at the speed the lathe runs makes me look at tap and die sets.
I do know that a slow gear set is availavle for my lathe but at £60/£70 I am still looking at taps and dies.
Les Jones 101/05/2011 11:03:43
2292 forum posts
159 photos
Hi Chippychap,
A rheostat is not the same as a variac. A rheostat is another name for a variable resistor. A variac is a variable auto transformer. (I think variac is actually a manufacturer.) From the limited information I can find on your lathe I think the motor is an induction motor. (If it is it will not have brushes.) The speed of these motors cannot be controlled effectively. Your best option would be fitting a three phase motor and inverter package. These have been discussed several times before on this forum. The gear set would have the advantage of giving more torque at lower speeds.
Les.
ady01/05/2011 11:18:42
612 forum posts
50 photos
I would say yes...but:
I recently did a pretty huge job using backgear on my lathe and was amazed by the amount of non-stop hard work a lathe can do, and I was VERY glad that I did not have to subject an expensive 1/2HP electric motor system to this level of effort.
In-my-opinion
Gearing and a decent single speed motor is the way to go if you're going to get serious at this hobby and work your lathe hard at times.
Taps and dies are too restrictive for threadcutting, especially where concentricity is important.
I often partially cut a metric thread on the lathe, then finish with a tap or die so that concentricity is "guaranteed".
Once you get some skills you will be in a position to put whatever thread you want onto or into whatever thickness of bar you want.
For very small threads taps and dies are very useful, I only have a basic metric set.
They are also very useful for cleaning up important threads, i have a few big imperial ones for cleaning out my mandrel/chucks etc.
Edited By ady on 01/05/2011 11:39:57
Edited By ady on 01/05/2011 11:48:31
Chippychap01/05/2011 11:18:51
11 forum posts
Thank you Les.
What is it they say, "If it seems too good to be true then it probably is"?
Steve Garnett01/05/2011 11:48:11
837 forum posts
27 photos
Ady's right - but with the best will in the world, a Hobbymat MD65 isn't going to be a major workhorse. Well mine isn't; it's just not that chunky a lathe. And yes it has a reversible induction motor. It's not impossible to control the speed of these - they are only a single-phase version of a three-phase induction motor after all, but if I was going to do this, I think I'd swap the motor out for a three-phase one anyway and save a lot of hassle.
The other major consideration with an MD65 though is that its lowest speed as standard is 200rpm - way too fast really. And even though you could achieve a much lower running speed with some sort of speed-controlled motor it would be running way outside its range of effective power production and be compromising the cooling somewhat. So if you were going to go for a lower running speed, I think that you'd be rather better off leaving the motor alone, and going for one of the low speed belt conversions. I'm pretty sure that these are still available, and it wouldn't be beyond the realms of possibility to make one for yourself, either. I suppose that if you were going to be really flash, you could do the motor swap as well - but I'd keep asking myself whether on this lathe it would really be worth it, quite frankly. They are okay for what they are, but they have some distinct limitations. A big one is with the leadscrew, and it's this, along with the 200 rpm min speed that make any form of thread turning very difficult to achieve.
All these things are fixable, I suppose - but you'd have to ask yourself very seriously whether it wasn't worth saving the money you'd spend for a lathe where you'd have to make rather less compromises. I have no intention of keeping my Hobbymat in the long term; it's quite useful at present for fixing bits of the Kerry I'm slowly rebuilding, but I'm certainly not going to throw any more money at it for improvements.
Peter G. Shaw01/05/2011 13:21:18
1531 forum posts
44 photos
When I had a Hobbymat, after frightening myself when attemptint screwcut at the minimum speed (250rpm on mine) I fitted a slow speed adaptor made by Essel Engineering. This gave an additional two lower speeds of 63 & 125rpm and from memory was a simple bolt-on system.
If these adaptors are still available, or if one could be copied (perhaps I shouldn't have said that) this would perhaps be the best way to go. If they do cost your £60-70, although it does sound a lot, the kit I had was very well engineered and if you do need the slower speeds, very well worth while.
As an aside, 63rpm, after getting used to 250rpm, does seem exeedingly slow!
I have just looked at the Essel Engineering website, and find that they are still advertising "As a further service to modellers, we also supply 'Hobbymat' small machine tools, accessories and spare parts." But it doesn't say what they supply, so perhaps an enquiry.
Peter G. Shaw
Nicholas Farr01/05/2011 13:47:51
3988 forum posts
1799 photos
Hi, I agree with both what Ady and Steve say, and as you may have seen my photo album about the Hobbymat refurb that I am slowly doing, 7 years so far, but to be honest it sat in my garage taking a somewhat back seat for most of that time. It was bought second hand of ebay and had some modifications done to it by a previous owner. I like Steve don't intend to throw very much money at it, about £20.00 so far for paint and a new piece of Ally and that will be about the limit. But on the question of £60/70 for adding a slow drive to the V belts I would think is quite a small amount compared to the cost of a three phase motor and converter.
I don't consider the Hobbymat as a serious lathe, but are a good budget one, and probably got a lot of people started in this wonderful world of ME who wouldn't otherwise been able to afford it, when they first arrived on the scene. They still seem to attract a good price second hand though.
Regards Nick.
Steve Garnett01/05/2011 14:10:25
837 forum posts
27 photos
Peter is correct - it's 250rpm; I should have looked it up rather than trying to remember the number, obviously.
If you look on Tony's lathes site here you can see pictures of how the slow speed drive is achieved, and I wouldn't have thought that doing this was too difficult. Even this mod only gets the speed down to 78rpm (so you can play old records on it!), but that's quite an improvement, and will certainly maintain the torque at a lower speed, which is more than a varispeed arrangement will do if slowed down that much. Tony has probably still got mod kits, I'd guess.
But Nick's right - it's a good budget lathe, as long as you recognise its limitations. Yes mine needs a paint job too, and possibly also the same bit of ally (are we talking about the plate that supports the leadscrew handwheel?). The only reason that I might consider the 3-phase motor mod is because I think I have one that might physically fit. But I'm still having an argument with myself about whether or not to save it for something else.
So far the lathe has cost me nothing - I stopped it going in a skip. It now has a quick-change toolpost that was a Christmas present, and I'll keep that regardless. I have absolutely no objection to keeping a small lathe as well as a larger one, but somehow in the long run, I don't think it will be the Hobbymat.
Nicholas Farr01/05/2011 14:24:15
3988 forum posts
1799 photos
Hi Steve, the ally was for the change wheel apron, see pic at top of this thread. The leadscrew support was originally Bakelite but I made a new one from part of a cast iron bearing housing, but I suppose ally would do for that, its just that the scrap bearing housing cost me zero cash.
Regards Nick.
Edited By Nicholas Farr on 01/05/2011 14:38:45
Steve Garnett01/05/2011 15:09:16
837 forum posts
27 photos
The change wheel apron on mine's okay, but I have to make a new leadscrew support, because part of that bakelite has cracked away around a mounting screw. Because of the overall hassle with the leadscrew in general, I was also thinking of fitting a small reversible motor drive to it as well, and doing this by extending the plate somewhat. I've probably got enough bits for that, so it's still either a zero or very low cost mod.
Regds, Steve
Chippychap01/05/2011 15:10:41
11 forum posts
Thanks guys,
For me the Hobbymat is here to stay. It lives in the house and lack of space makes it a keeper.
The slow speed gears thread has gone straight into my "Favourites" and thank you for that.
The Essel set up is the one I have been quoted seventy quid ish for, as you say it is cheaper than the 3 phase conversion.
I guess the easiest way is to adapt, alter and add to the lathe as I need to rather than solve problems that I haven't encountered yet.
Nick, you sent me a photo of your lathe when I had probs with the cross slide, I'm going back to see the series about you fettling your hobbymat.
As always thank you ALL
Nicholas Farr02/05/2011 01:27:34
3988 forum posts
1799 photos
Hi Chippychap, I'm glad that you have found something usfull from my H/M lathe refurb album, but as I've said there is a little more to do when time allows.
Steve, I have added two drawings of the spindle plate, to my H/M album that I made with the measurements that I took at the time, which seemed to be closer to imperial than metric, with the exception of the two pin holes that hold the leadscrew gaurd, although all measurement are in decimal imperial on the drawings. I have got a write up in M/S Word of the brief proceedure with photos of making mine if you are at all interested, I can e-mail them if you like.
Regards Nick.
John Olsen02/05/2011 07:45:36
1294 forum posts
108 photos
Well there are speed controls, and then there are speed controls....The type of thing that works on a universal motor, eg the ones with brushes, don't maintain torque very well at low speeds. They are OK for slowing down an electric drill, but not much more.
The type that work on a three phase motor are much better, and will give good torque at slow speed. However, at best you are only going to get the same maximum torque when going slow. So you can get it slow enough to keep control for screwcutting, but it will not replace a backgear for doing heavy cuts.
So the ideal is of course to have both, eg a back gear or the equivalent for gearing down to allow turning things like flywheels at low speed but with a good cut...I shouldn't really say heavy cut because none of our smaller lathe really take what could be called a heavy cut, but I mean heavy enough that it is reasonable to attempt the job. Then if you also have a motor speed control, you can screwcut at low speed, and return to the start in reverse at high speed.
regards
Chippychap02/05/2011 09:03:33
11 forum posts
Thank you John.
Steve Garnett02/05/2011 10:33:40
837 forum posts
27 photos
Posted by John Olsen on 02/05/2011 07:45:36:
Having done some experiments with this lately using a fractional horsepower motor and a controller where the torque compensation is very flexibly adjustable, I'd say that that it would appear that the torque holds up better with larger motors - anything over 1HP, it certainly works reasonably well. This may well be a limitation in the particular small motor I was testing, admittedly - but it does go to show that you'd really need a tried and tested solution before you were going to rely on it for low-speed running, I'd say. And you still have the cooling problem to cope with, and that would definitely be worse if you significantly loaded the motor while it was running slowly, especially if it was being significantly torque-compensated.
So as far as I'm concerned, it would definitely be the belts and pulleys solution first, and only then consider a 3-phase motor on the Hobbymat - if I was going to do it at all, of course!
Steve Garnett02/05/2011 10:44:21
837 forum posts
27 photos
Posted by Nicholas Farr on 02/05/2011 01:27:34:
Thanks Nick - the basic layout measurements will be useful. Since I'm going to modify the leadscrew bearing arrangements to take account of a power feed, etc, and the rest of the plate will be different anyway, I think I may have to figure out my own way of doing the job! But a kind thought, so thank you.
But I do have another question about what you've done - which plasti-kote paint did you use, and how did you get on with it?
Nicholas Farr02/05/2011 14:58:02
3988 forum posts
1799 photos
Hi Steve, it is No: 107S Sunshine Yellow in the 100ml spray cans at about £2.49 each when I bought them. Not sure if they were on offer at the time, but it took almost four of these. They weren't to bad to use, but they don't like the cold too much, so I stood them on my oil filled radiater for a while before use, as it was just a little before Chrismas time when I did It, however I did prime the Ally with Hammerite Special Metal Primer first, which I allready had, and the saddle and tailstock had a coat of grey Plasti-Kote primer which I also already had. No real effort was made as it was only intended to be a tidy up job, I'm no painting expert.
The colour match wasn't exact, but it looked pretty close and good enough for me.
Regards Nick.
paul ellis02/05/2011 15:34:41
1 forum posts
hi all i have an 8" chuck for sale unused with reverse jaws if any one needs 1 fo 60 pound call me on 07807 428666 if interested.
Steve Garnett02/05/2011 16:31:35
837 forum posts
27 photos
Posted by Nicholas Farr on 02/05/2011 14:58:02:
Neither am I - and I certainly have quite a bit to do on various refurbishment projects, so I'm very interested in how people get on with the various painty substances they use, so thanks for the info.
As far as the Hobbymat is concerned, I have to repaint the tailstock from scratch. The top of it got somewhat 'abused' in its previous situation (heaven knows why), so I've cleaned it up and linished the abuse away, but I reckon that the chances of an exact match are minimal - hence having to do the whole thing.
Paul, no Hobbymat lathe I've ever seen or even dreamed of could take an 8" chuck!
Regards, Steve
Edited By Steve Garnett on 02/05/2011 16:33:06
