John Coates | 07/12/2010 20:51:29 |
![]() 558 forum posts 28 photos | Well the learning is progressing well and I am merrily milling and lathing (?) One problem I am finding is when changing between the drill chuck, collet holder or boring head in the mill, because they are all different lengths, once the head is unlocked from the column, when winding the height adjust handle I lose alignment My mill is a Chester Champion Is there any way of retaining the relative position of the head during these changes or is my only way to mark the head and column with reference lines? Thanks for any help John |
wheeltapper | 07/12/2010 21:08:13 |
![]() 424 forum posts 98 photos | Hi
one way I've seen in a mag is to get a cheap laser pointer and fix it to the mill head pointing toward a wall, line the head up and mark a line on the wall where the pointer is . then when you change heights, reline the mark.
there are other ways but they involve modding the mill somehow.
just a thought.
Roy |
Gray62 | 07/12/2010 22:02:20 |
1058 forum posts 16 photos | I used to own the Warco equivalent of this mill, to maintain alignment, I made a bracket that attached to the head which was a close sliding fit with a stationary vertical 20mm bar, attached to the column by another bracket. I recall there was an article in MEW along these lines but so far I cannot find it. |
Gray62 | 07/12/2010 22:13:28 |
1058 forum posts 16 photos | Aha, found it, issue 108 of MEW has the details of the principal I implemented, an article entitled 'Round with Dovetail Advantages' |
Gray62 | 07/12/2010 22:26:45 |
John Coates | 07/12/2010 22:55:28 |
![]() 558 forum posts 28 photos | Coalburner - unfortunately I only started my subscription at 160
![]() But a bracket at either end to which I could attach a solid bar sounds workable
And thanks wheeltapper for the laser level suggestion |
dcosta | 07/12/2010 23:07:23 |
496 forum posts 207 photos | Hello John Coates. It had ocurred to me that an rotary encoder may, eventually, give You sufficiently accurate information for the purpose of the alignment of Your mulling column. And it is a very clean solution. Please look at the following URL Best regards Dias Costa |
Gray62 | 07/12/2010 23:15:34 |
1058 forum posts 16 photos | The subscription to the digital mag archives is well worth it, then you get access to any MEW from issue 1 to current, I don't regret taking up the subscription, saved me a fortune in buying magazines from ebay etc ![]() |
chris stephens | 08/12/2010 11:58:00 |
1049 forum posts 1 photos | The pound shops often sell laser levels at, you guessed it, a pound. One of these mounted on your mill will project a line to a far wall, and more than adequate alignment precision can be achieved.
chriStephens
John Coates | 08/12/2010 12:32:12 |
![]() 558 forum posts 28 photos | Thanks guys
I think I'll go for CoalBurner's solution as I plan to move the mill and the end position might not be too favourable for access to walls
I tend to keep the mill head in the same position when doing indexing (is that the right word for what I'm doing - moving the workpiece between positions to carry out sequential operations?)
So having a rigid bar to control the alignment will not cause me problems and another member has messaged me about how such a device can be constructed
John |
