Grease nipple threads
graham williams 102/11/2010 07:28:52
13 forum posts
Have a few grease nipples that I need to use on a project I'm building but can't recognise the threads or get an accurate TPI. They're tapered max dia 1/4". Got BSF/Whit/UNC/UNF/BA/BSP/Metric taps but nothing fits. Anyone know what the thread is or where I can get some replacement nipples with a thread size for one on the taps I have?
Bogstandard02/11/2010 08:03:52
263 forum posts
Grease nipples are made with a variety of threads, depending where and when the bits to fit them to were made, but the most common ones are BSP or metric.
These are a bit pricey but at least you will have enough to last a lifetime
I bought some about a year ago, I only needed half a dozen. At one time you could go to your local motor factor and get them, I tried them all around my place, even Halfords, but it seems they run out years ago as most things now are sealed for life, but your local engineering  supplier or farming supplies should be able to help you out, but most do have a minimum order. I finished up buying metric ones.
I hope this puts you on the right trail.
Bogs
Andrew Johnston02/11/2010 08:30:53
7061 forum posts
719 photos
Depending on the source might be NPT; a US self-sealing pipe thread equivalent to BSPT. However, 1/4" maximum diameter sounds a bit small for NPT, or BSP.
Ian S C02/11/2010 08:47:57
7468 forum posts
230 photos
The ones I'v got at 1/4" are UNF. I think I have some someware with a finer thread.Ian S C
KWIL02/11/2010 08:52:05
3681 forum posts
70 photos
www.lubetec.co.uk     seem to have them all
graham williams 102/11/2010 12:01:05
13 forum posts
Thanks to everyone who replied. Have found a place locally to me who has a variety and who will sell me the 4 I want (didn't really want to send for an assortment from RDG or similar) and with a thread that I have a tap for.
