Titanium
macmarch27/10/2010 17:00:50
147 forum posts
Can anyone help with sourcing Titanium wire, grade 1,2,3, or 4?
I need it at about 2mm dia and a total length of about 2 metres. I would also consider changing my design if it was available something like 1mm x 6mm flat in a hard condition.
cheers
Ray
KWIL27/10/2010 17:10:10
3681 forum posts
70 photos
Have you tried www.titaniummetals.co.uk?. They list 2mm wire in two grades.
macmarch28/10/2010 12:23:30
147 forum posts
Cheers Kwil,
I had looked all over t'internet but no one actually sells small quantities, not even TML.
If I order 2m of 2mm wire the cost is £75, call in and pay cash = no min order value.
thanks
ray
Andrew Johnston28/10/2010 12:44:54
7061 forum posts
719 photos
How about this place:
David Clark 128/10/2010 12:57:57
3357 forum posts
112 photos
10 articles
Hi There
Have you tried jewellery suppliers?
regards David
macmarch28/10/2010 13:03:36
147 forum posts
If I go and collect from TML then price is small but will use £30 petrol. Twistfix gives 5 times as much delivered for less than the petrol. Classic example of not what you know but who you know. Thanks for all help. problem solved.
cheers
Ray
Tony Jeffree31/10/2010 13:13:39
569 forum posts
20 photos
I have used reactive metals in the USA as a source of Titanium wire before now:
http://www.reactivemetals.com/
They are very responsive & don't have a minimum order if I recall correctly.
Tony
John Stevenson31/10/2010 13:23:44
5068 forum posts
Titek in Birmingham do exactly what you need.
http://www.titek.co.uk/others.html
Nice company to deal with, you want 200mm of 30mm Titanium and they will cut it and ship it. I buy just what is needed when I need Titanium because of the cost.
John S.
macmarch31/10/2010 15:22:56
147 forum posts
I have now purchased a supply of Titanium.  It wasn't the quantity that caused the problem but the size.  2mm wire. Nearly every source started at 6mm.
All I have to do now is to make plastic toolmakers clamps with the wire clamped at the bottom.  If it works as it should I'll put the dwgs up for anyone else to use.
cheers all
