Machining In Your Workshop Special
David Clark 125/09/2010 16:21:19
3357 forum posts
112 photos
10 articles
Hi There
Finally finished the machining of a Blackgates Vee twin oscillating engine.
This Special has a fully detailed article about how I built this engine.
The article comprises 160 photos showing most of the machining setups used.
It was made on a Myford lathe and Tom Senior mill.
You can order this special from MyHobbyStore.
Cornish Jack25/09/2010 17:45:01
1228 forum posts
172 photos
Splendid!! Have had a set of castings lurking in the 'to do' pile for some time.
HOWEVER ... Although I can log in here, when I try to order a copy the required log in FAILS with an 'incorrect password' box!! "Curiouser and curiouser ", said Alice.
Engine Builder25/09/2010 19:25:38
267 forum posts
You need to create an account for myhobbystore. Your password for the ME site will not work.
Stub Mandrel25/09/2010 20:53:39
4318 forum posts
291 photos
Great stuff David,
But does it work
David Clark 125/09/2010 21:08:18
3357 forum posts
112 photos
10 articles
Hi There
Not yet, Nearly ready to test. Need a couple of o rings.
Gave up trying to fit the graphited string. Everything is free and it turns well.
Happy with the machining operations. Will add an 'I would do this differently next time' box at the end of the article. This is only dimensionally, not machining.
Under pressure to finish writing it up so it can go to press. Will have more time to play next weekend. Hope to put it into the loan section at Sandown.
regards David
Cornish Jack26/09/2010 17:22:15
1228 forum posts
172 photos
Ah ha!!, thank you, Engine builder
Foolishly thought that  having a link to the thing on here would make access straightforward.
Methinks Alice was right!!
John Olsen27/09/2010 01:20:19
1294 forum posts
108 photos
Never mind the O rings, if you put enough air on it the leaks won't matter! Remember they will more clearance on a job like this too.
I think graphited yarn is to make you feel like you have tried rather than to actually acheive much. Bit like the Dunstall muffler on my old Triumph, you were supposed to wrap the inner perforated tube with fibrelass to absorb the sound, but whenever I checked there was never any in there. Didn't take long after repacking for the crackle to come back in the exhaust either.
I saw an interesting variation on the oscillating idea this weekend, a little three cylinder radial, with fixed cylinders, and little valves pivoted at much the same place as the cylinder would have been, and using a fork onto the crankpin to operate them. Gives the same sort of timing. Downside is the steam (and exhaust ) connections have to be flexible, since the connection is directly onto the moving part of the valve. With a bit of ingenuity I'm sure that expedient could be avoided.
regards
Stub Mandrel27/09/2010 21:04:59
4318 forum posts
291 photos
My wife thought a poor cat  had been sucked into her Vectra's exhaust - it turned out to be fibreglass blowing out of it. I tried driving it and every so often you would lose power, then there would be a pop and it started working OK again.
