Freddybear | 13/06/2010 14:01:09 |
![]() 27 forum posts 54 photos | Hi Does anyone know were I can get an original type vice for my boxford 8" shaper. The one I ma after comes with a square rotating base with 4 fixing holes. 1 in each corner. |
Freddybear | 17/06/2010 18:19:02 |
![]() 27 forum posts 54 photos | it should look like the one in the picture below ![]() |
Freddybear | 21/06/2010 21:25:57 |
![]() 27 forum posts 54 photos | Come on, someone out theremust know were their is one! |
Stovepipe | 21/06/2010 22:32:59 |
196 forum posts | Have you thought of putting an advert in the "Wanted" advert section ?
Dennis |
_Paul_ | 22/06/2010 07:47:12 |
![]() 543 forum posts 31 photos | I too have a 8" Boxford Shaper and have searched far and wide for an original (or original looking) vice with no luck even contacted Boxford themselves to see if they perhaps had any "old" stock lurking about their response was no as that they had not made the shaper in 30 yrs. Hope you have better luck than I. Regards Paul |
Freddybear | 22/06/2010 20:14:48 |
![]() 27 forum posts 54 photos | I have an ad in the wanted section, but have not had 1 response. It seems there are a great many shapers out there with no vice. Were are they all? Edited By Mark smith 9 on 22/06/2010 20:15:16 |
Versaboss | 23/06/2010 23:24:30 |
512 forum posts 77 photos | Mark, if that would help you, I could measure the principal dimensions of the Boxford vice. I am sure that a simple commercial vice could be adapted for the shaper. I would think that finding an original one (without a shaper attached to it Greetings, Hansrudolf |
Freddybear | 24/06/2010 14:09:29 |
![]() 27 forum posts 54 photos | Hi Hansrudolf, Thats sounds like an excelent plan B. Thank you very much. Any information you are able to provide will be of great help. May I impose on you a little more and ask if you could post a good quality photo of yours too. Thanks again regards Mark |
Terryd | 24/06/2010 16:43:11 |
![]() 1946 forum posts 179 photos | Hi Mark, I'm probably teaching my mother to suck eggs but be careful to make sure that any vice you have has the 4 bolt mounting. Using those with just 2 bolts, as most milling vices are, could lead to the tee slots of your shaper table being ripped out as the forces in shaping can be considerable. As for your question "where are they all," as Hansrudolf says, they are probably attached to their shaper. Also, many of these small Boxford shapers were used in schools and the vices would be used for all sorts of things including, milling and drilling, and if you see the state of some of these after 20 or 30 years of teenagers drilling holes in them you too would have scrapped them. Remember, there would have been no more vices than shapers. Terry |
Versaboss | 26/06/2010 15:12:53 |
512 forum posts 77 photos | Hi Mark, I put a couple of pictures of the vice in my 'album'. As usual, can't remember how to give a link to the album here, so you will have to search - sorry! It differs from your picture a bit; it has no rectangular plate beneath the vice. The vice is directly fixed to the 'cube' by a large central stud. If I would have to mount another vice I would make such an intermediate plate. This should give a very rigid mounting, but needs a bit of height. Dimensions of the vice (in mm, if you don't mind): width 105 mm depth of jaws: 26 mm max. opening 107 mm total height above cube: 60 mm diameter of the round foot with the degree scale: 110 mm I would like to have that rotating type of cube on my shaper; i think this is very rare in that size!
John Olsen | 04/07/2010 10:20:23 |
1294 forum posts 108 photos 1 articles | Hi Guys, Shapers are often missing their vices. This is due to the fact that a shaper vice is a good substantial device, ideal for use on the milling machine that quite likely replaced the shaper. A good milling vice will do instead, although shaper vices tend to be a lower profile for a given size than a milling vice. This only matters when you need to do bigger jobs, in which case you should think about attaching it directly to the table. TerryD, if you are getting substantial forces when you are shaping you are doing it wrong. This is a single point tool remember, the forces should be of about the same order of magnitude as you get on a lathe. The original vice for my 6" Ammco shaper was held down by a single bolt in the middle, through the table. (I don't have one, but have the castings to make two of them and a set of drawings.) The original vice for my ten inch Alba is held down by two bolts, and has a swivel which is also only secured by two bolts. It is only when we get to my 18 inch Alba that we find a vice with four bolts on both the swivel and the table mounting, but then that is a substantial bit of kit. It takes a bit of thought to get it on and off the table. Where the vice needs to be substantial is that at times you will find you must cut parallel with the line of the vice jaws. This tends to move the job in the jaws, and of course the tool may pick up the end of the job, leading to mayhem. So for this situation, the job wants to be clamped really firmly, preferably with a bit of paper each side to improve the grip. This is one reason why thinking about attaching the job directly to the table is a smart thing to do. Another good plan is to see if you can provide a positive stop at the downstream end of the job. Generally if the job starts to move you will see it happen, and the machine will probably manage about three strokes before you get to the power switch. If you are lucky you will only break the tool and spoil the workpiece. Still, similar things can happen on milling machines and in lathes too. The tilting table is a nice feature, but the downside is that having tilted it you now have to get it back in true again for the next job. So it is a bit like offsetting the tailstock on your lathe, or tilting the head on your mill drill. The one on my ten inch Alba will tilt, but I don't recall ever having used the feature in over ten years. But now if I could get hold of a slotter attachment for one of my machines.... regards John |
