Northumbrian AXLE BOX SPRINGS
Can't seem to find wire gauge and dimensions for leading axle box springs
bellerophon04/03/2010 08:18:26
24 forum posts
I have found the dimensions for the trailing axle springs but can't seem to find the driving axle box spring dimensions - am I missing something or can anyone tell me what wire gauge to use and what the  spring dimensions (turns and overall height) should be?
Thanks
Donald Campbell
Chris08/03/2010 08:54:59
87 forum posts
13 photos
Try Part 5, Fitting the Wheels and Axels, page594, where there are instructions on making the springs and wire sizes.
22g for the driving and trailing wheels. 1 1/4 for the drivers and 5/8 for the trailing. Tender springs are recommended at 26g and 5/8. (Part 9, Page 257).
Can you recommend a supplier of piano wire Donald as I haven't found one yet.
Chris.
Edited By Chris on 08/03/2010 09:09:25
KWIL08/03/2010 09:10:19
3681 forum posts
70 photos
Reeves 2000 have these guages in stock according to Cat.
MichaelR08/03/2010 09:10:31
528 forum posts
79 photos
Model Aircraft stockists should have Piano Wire, try this oneHere
bellerophon08/03/2010 10:49:07
24 forum posts
Thanks to Chris - yes REEVES 2000 keep stainless spring steel wire for this ([email protected] - from memory about £7.50 per 7 metres)
Donald campbell
JasonB08/03/2010 13:28:09
For chris and anyone else who has not used piano wire before, don't try cutting with a pair of pliers or sidecutters unless you want to damage the cutting edges. Small cut off wheel in a dremel type tool is probably the best option. Don't think you really need to go for stainless in this application, save it for safety valve springs etc, the cheaper piano (music) wire will do the job. The model aircraft shops keep it in about 36" or 1m lengths, a 0.5 kg coil from Reeves will last several lifetimes.
Jason
Edited By JasonB on 08/03/2010 13:31:04
Chris09/03/2010 17:05:43
87 forum posts
13 photos
Thanks to all for the addresses and Jason for the cutting methods. I was just about to dismantle the old Joe Anna for parts! The way I play the piano the neighbours would probably have been grateful.
Chris
bellerophon18/03/2010 08:05:05
24 forum posts
REEVES PIANO WIRE IS CHEAPER THAN I THOUGHT!! it's more like £3 - no connection with them other than as a satisfied customer
Donald Campbell
