JasonB | 09/02/2010 20:34:34 |
![]() 25215 forum posts 3105 photos 1 articles | Just spotted a few errors on these drawings
Base plate (both drawings) the overall size of the cut out is given as 1/4" (25mm) assume it should be 1".
Also on the base plate there is no way of locating the cutout vertically. I think it should align with teh 1/8 & 1/4 hole positions abu as drawn the cutout lines do not line up with the centre holes.
Flywheel The side elevation gives a total rim thickness of 1/4" but the section gives 1/4 + 1/16
Don't know if the metric dims are a new addition or from the original article but if newly added can they be consistant. 1 1/4" is shown as both 30mm and 32mm. 7/8" is given as 24mm and 25mm when its usual to round it to 22mm
I'll let you know if I see any more |
David Clark 1 | 10/02/2010 09:03:12 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
I just posted the drawing as is.
It was drawn about 20 years ago.
I will update when I get time.
regards David
Terryd | 10/02/2010 21:25:11 |
![]() 1946 forum posts 179 photos | There also appears to be a mistake on he positioning of the holes for the side brackets of the main body. Th one on the RH side of the cutout is marked as being 15/32 (12) and it appears way out of alignment with a lower hole for the pillar which is marked as 1/2 (12). I know as an ex engineer not to, scale drawings but this looks wrong especially as the corresponding left hand hole is marked as being 21/32 (16) from centre which makes it only 11/32 in from the edge, which I suspect, is the correct dimension in for the right hand hole and not the 15/32 shown. |
Terryd | 10/02/2010 21:28:23 |
![]() 1946 forum posts 179 photos | By the way, there are two copies of the Terium Quid baseplate drawing in the 'Best Of Model Engineer Vol 2'. one on page 21 and one on page 23. Is this significant? |
JasonB | 11/02/2010 07:25:29 |
![]() 25215 forum posts 3105 photos 1 articles | Valve nut is also given as 4/32 (7) should be 9/32
J |
Stub Mandrel | 14/02/2010 22:10:20 |
![]() 4318 forum posts 291 photos 1 articles | I've been trying to find the Stan Bray articles on the site and can't. Could you point me at Tertium Quid and Lusus Naturae please? TIA Neil |
JasonB | 15/02/2010 07:29:00 |
![]() 25215 forum posts 3105 photos 1 articles | They are in the "Best of Model engineering Vol II" don't think its on the site.
Jason |
David Clark 1 | 15/02/2010 09:06:47 |
Yes, in the best of.
A couple of minor corrections are on the site.
regards david
Stub Mandrel | 16/02/2010 21:58:08 |
![]() 4318 forum posts 291 photos 1 articles | Have to go shopping then! Neil |
