Goran Hosinsky | 06/01/2010 20:15:03 |
41 forum posts | I have to modify the motor setup of my Chinese lathe and would like to take the oportunity to add a somewhat lower minimum speed than the present 115 RPM. What bottom speed should I aim for? 50 RPM looks to be fairly easy to reach but I see, that the Myfords go down to 30 RPM, which would be rather more difficult, but probably doable. Goran Canary Islands |
KWIL | 06/01/2010 20:37:32 |
3681 forum posts 70 photos | If you fit a three phase motor and use an Inverter you can run it as slow as you like, provided that you watch the motor temperature. I use an almost stopped speed to clock under power. |
Goran Hosinsky | 06/01/2010 20:52:15 |
41 forum posts | Yes, but I am looking for a locally available, cheaper solution |
Tony Pratt 1 | 06/01/2010 21:23:36 |
2319 forum posts 13 photos | Hi, from my experience 50 rpm will be fine. Obviously there will always be that job which needs a slower speed but not too often.
![]() Tony |
Keith Long | 06/01/2010 21:37:12 |
883 forum posts 11 photos | Hi Goran As Tony says 50 rpm should be OK, if you want to do screw cutting you may want to go lower, but an alternative would be to rig a handle to allow you to turn the lathe over by hand and cut the threads that way. Cutting threads shouldn't take much power (effort) as too big a cut, you'll probably snap the tool anyway. If you want to go to lower (powered) speeds then I think the easiest way, if your changing the motor arrangement, would be to put in either a very big pulley as the input to a counter-shaft from the motor or look at rigging a two stage counter-shaft system. Which Island are you on? Keith |
Goran Hosinsky | 06/01/2010 22:43:34 |
41 forum posts | With pulley for 50 rpm I do not need to change the protective cover, for 30 rpm I have to modify or make a new on. Isla San Miguel de La Palma, the island with the big observatory Goran |
Gordon W | 07/01/2010 09:51:10 |
2011 forum posts | I've just fitted a bigger pulley to my small lathe. Bored out inside to fit over existing pulley, scewed flat plate to outside of new pulley, tapped 4 holes in existing pulley (just missed the second V), this gives me about 60 rpm. Need a longer belt, and end cover has to open, or modify to suit. The new big pulley has a flat top, not Veed, and works OK. I use a mandrel handle for screwing, for short threads, this works fine. Big pulley can even be made from good plywood. |
